Local Time 05:52 14 Sep 2026 Privacy Policy
Forum Index : Microcontroller and PC projects : SNAP programmer
palcal
Posted: 06:11am 17 Oct 2023
Just got a new SNAP programmer from Microchip. My Pickit 3 clone stopped working.
The new tool is recognised by MPLAB but when I try to connect I get this error.
  Quote  You have entered an invalid value (null) for the Voltage Level on the Snap Power property page
I can't find where to change the Voltage Level. I've searched Microchip for the answer but can't find anything.
HELP!!!
Posted: 08:39am 17 Oct 2023
Hi PalCal,
Based on my using of the pickit3 there is a section in the menu for Advanced options that prompts for a password that brings up a menu
The password is
microchip
Maybe the setting is in there.
mick
barewires
Posted: 09:33am 17 Oct 2023
According to the Microchip Forum:
https://forum.microchip.com/s/topic/a5C3l000000MebqEAC/t386157
Snap doesnt have any power output.
It relies on DUT having its own power supply.
palcal
Posted: 07:47pm 17 Oct 2023
Yes I've read that and gone into advanced settings. In advanced settings you can only select high or low power programming. There is no provision anywhere to set a voltage value.
palcal
Posted: 09:20pm 17 Oct 2023
I changed chips and successfully programmed a PICMX170, I am trying to program a PIC16F1455 in a ZIF socket, so maybe not good contact, will look into it. I suspect the error about voltage is some sort of error in itself.
zeitfest
Posted: 11:54pm 18 Oct 2023
IIRC the 16F1455 as supplied has a configuration bit set that prevents LVP by default, so initially HVP is needed, I think the SNAP is LVP only ?? (unless another voltage source is present ??)
Also 16f1455 uses different pins for LVP cf. HVP, maybe check the pins used for programming.
palcal
Posted: 03:35am 19 Oct 2023
I now have a feeling the chip was already programmed, I have had the chips for years and maybe programmed them all when I received them. They are SOIC so I will have to solder one in and test it when the boards arrive.
Posted: 07:24am 29 Oct 2023
Modifying the Snap programmer to provide power.
Silicon Chip June 2021 page 69.
There are 5V and 3.3V pads near the voltage regulator, about 6mm apart.
Snip the middle pin off a 3 pin header socket, spread the pins a little to match those pads and solder to the pads.
Snip one end off a Dupont wire and solder it to pin 2 of the programming header socket.
Plug the other end into the required voltage.
amigawizard
Posted: 10:38am 29 Oct 2023
27.2 Low-Voltage Programming Entry
Mode
The Low-Voltage Programming Entry mode allows the
PIC® Flash MCUs to be programmed using VDD only,
without high voltage. When the LVP bit of Configuration
Words is set to ‘1’, the low-voltage ICSP programming
entry is enabled. To disable the Low-Voltage ICSP
mode, the LVP bit must be programmed to ‘0’.
Entry into the Low-Voltage Programming Entry mode
requires the following steps:
1. MCLR is brought to VIL.
2. A 32-bit key sequence is presented on
ICSPDAT, while clocking ICSPCLK.
Once the key sequence is complete, MCLR must be
held at VIL for as long as Program/Verify mode is to be
maintained.
If low-voltage programming is enabled (LVP = 1), the
MCLR Reset function is automatically enabled and
cannot be disabled. See Section 6.5 “MCLR” for more
information.
The LVP bit can only be reprogrammed to ‘0’ by using
the High-Voltage Programming mode.
      Wayne  !
