Local Time 05:51 14 Sep 2026 Privacy Policy
Forum Index : Microcontroller and PC projects : £45 7" nice display
stanleyella
Posted: 08:11pm 24 Oct 2023
https://www.buydisplay.com/download/ic/LT7683.pdf
looks interesting for price and it's spi
Posted: 08:15pm 24 Oct 2023
That's the spec for the controller chip. It's not for a display.
stanleyella
Posted: 04:24pm 25 Oct 2023
https://github.com/GreatCowBASIC/Help/blob/main/seven_inch_gcld/referencedocs/FocalTech-FT5x26.pdf
https://github.com/GreatCowBASIC/Help/blob/main/seven_inch_gcld/referencedocs/SSP0700A.pdf
£45 aliexpress
Posted: 04:39pm 25 Oct 2023
TBH without an explanation and an ali link that's a pain to figure out.
Posted: 05:35pm 25 Oct 2023
Don't hold your breath.
I don't think any capacitive touch controllers are supported by MMBasic, and neither is that  display controller chip. You can use 800x480 on the Armmite F4 (and there is a cheaper IPS display that will do it - I did a PCB for it) but not the PicoMite as you can't have a frame buffer that big.
stanleyella
Posted: 06:01pm 25 Oct 2023
It was posted on gcbasic forum as under development. A smart lcd that an 8bit controller can use. bit like nextion but cheaper and no ide needed.
Posted: 07:32pm 25 Oct 2023
Now, if you'd said that at the beginning....   :)
stanleyella
Posted: 10:02pm 25 Oct 2023
this for pico vga?
https://www.aliexpress.com/item/1005004670710687.html
