Local Time 04:58 14 Sep 2026 Privacy Policy
Forum Index : Microcontroller and PC projects : Possible MMBasic Windows Sprite Hide Safe Bug
LeoNicolas
Posted: 02:07pm 29 Oct 2023
Hello
I'm having the "Error in line XX: Not showing" error when trying to hide sprites safely. The error does not happen if I use sprite hide. Maybe it is a possible bug?
The code is running on the MMBasic for Windows V5.07.03
I isolated the code that causes the error.
dim s=1,i,o=20
mode 7,12 ' 320x240
page write 2: cls
load png "km_tileset.png"
page write 0: cls
for i=1 to 6
   sprite read i, 0, 128, 16, 16, 2
next
do
   o=20
   for i=1 to 6
       if s then
           sprite show i, o, 20, 0
       else
           ' sprite hide I <= This one works fine, the next line doesn't
           sprite hide safe i
       end if
       inc o, 20
       pause(500)
   next
   s=not s
   pause(500)
loop
The tiles file:
Posted: 07:27pm 29 Oct 2023
Please can you post the tiles file as a zip
LeoNicolas
Posted: 08:36pm 29 Oct 2023
  matherp said  Please can you post the tiles file as a zip
Please, let me know if you need any other file or info.
km_tileset.zip
Posted: 04:29pm 02 Nov 2023
The bug is there on the CMM2 as well. It appears it only relates to layer 0. If you set the layer to 1 it works OK - now I just need to find out why
sprite show i, o, 20, 1
LeoNicolas
Posted: 06:53pm 02 Nov 2023
  matherp said  The bug is there on the CMM2 as well. It appears it only relates to layer 0. If you set the layer to 1 it works OK - now I just need to find out why
Thank you matherp
