Local Time 00:02 14 Sep 2026 Privacy Policy
Forum Index : Microcontroller and PC projects : How to MQTT from Rpi Zero to Rpi Pico
Dinosaur
Posted: 12:03am 20 Nov 2023
Hi all
After completing this test I thought I would share with a Subject Title that would be found
by others looking for help on this.
'As a Dinosaur I need this reminder as to how to do it.
'1: On Rpi-Zero (the Broker), with Debian Bookworm
'   sudo apt-get install mosquitto mosquitto-clients
'   Create Hotspot (Rpi-Hotspot) with following settings:
'   Tick Connect Automatically,SSID = Rpi-Hotspot,Mode = Hotspot, Band = 2.4Ghz
'   Security = WPA3 Personal,Enter Password,IPv4 = Shared to other computers
'   Enter desired IP for Broker,Mask = 24,Gateway = same IP (it works)
'2: On Rpi-Pico
'   At Command line : OPTION WIFI SSID$,PASSWD$  will connect to Broker.
'                     OPTION WIFI Rpi-Hotspot,"*******"
'3: Run the Rpi-Pico program below,
'     A DO/LOOP continously calls TimeGet and TaskScan
'     As StepNbr is 0 at boot, that is the first Case taken.
'     Step -1 Connects & subscribes to topics
'     Step  1 Publishes TxValue every Minute.
'     Step 2 - 65535 can do what you like, but remember to reset to Step 1.
'     Don't do any loops in these steps, just check and set the next StepNbr, as that
'     means the others will get timely attention.
'4: On Linux PC (a Client)  , sudo apt-get install mosquitto-clients
'   Connect to Rpi-Hotspot, Edit connection as per Rpi-Zero with new IP
'   and route with Broker IP, then use the following but use your Broker IP:
'   mosquitto_pub -h 192.168.0.101 -m "Test Message " -t YourTopic -d
'5: When ever settings are changed, the Pico has to be reset.
OPTION EXPLICIT
OPTION DEFAULT NONE
Dim Integer CalTime,mSec,StepNbr,CommFlag,TxValue
Dim Integer StartTime0,Delay0,StartTime1,Delay1 'variables for  each Task
DIM AS STRING IP$
SUB MM.STARTUP                              'Initialise PicoMite
 RTC GETTIME                               'DS3231 on I2C GP8,GP9
END SUB
Sub MM.PROMPT                               'declare Time as Prompt
 Print Time$ ">";
End Sub
SUB Initialize
 Caltime = Timer                           'use this as mSec at program start
 mSec  = (Timer - CalTime)                 'mSec = elapsed since started
 Print "Step 0 "; CalTime                  'starting point at Boot
 iF StartTime0 = 0 THEN StartTime0 = mSec  'So that next delay is correct
 iF StartTime1 = 0 THEN StartTime1 = mSec  'So that next delay is correct
End Sub
Sub TimeGet()                               'get latest mSec & check Task Flags
 mSec  = (Timer - CalTime)                 'mSec elapsed since program started
 If mSec - StartTime0 >= 1000 Then         'If delay elapsed, allow action on it.
   StartTime0 = mSec :Delay0 = 1           'reset flags
 EndIf
 If mSec - StartTime1 >= 60000 Then        'If delay elapsed, allow action on it.
   StartTime1 = mSec :Delay1 = 1           'reset flags
 EndIf
 'Repeat here for StartTime2 to whatever
End Sub
Sub TaskScan                                'Step through each Task
 Select case StepNbr
   Case -1
     Print StepNbr
     WEB MQTT Connect "192.168.0.101", 1883,"Rpi-Hotspot","********",WebInt
     WEB MQTT subscribe "AmpHr"            'get what was sent
     WEB MQTT subscribe "Control"          'get Control Cmnd's from Rpi-Zero
     Print "Comm's Initiated"
     WEB MQTT PUBLISH "AmpHr",IP$, 0 ,1    'no reply but retain for Broker's use.
     Print mSec
     Print StartTime1
     StepNbr = 1
   Case 0                                  'At startup it comes here first
     If MM.INFO(WIFI STATUS) = 1 Then      'If we are connected
       IP$ = MM.INFO(IP ADDRESS)           'Get my IP address
       StepNbr = -1                        'Go Initialize
       CommFlag = 1                        'Flag to use later
     EndIf
   Case 1
     If Delay1 = 1 Then                    ' 1 Sec time is up.
       StepNbr = 2
       WEB MQTT PUBLISH "AmpHr",Str$(TxValue), 0 ,0    'no reply no retain
       StartTime1 = mSec :Delay1 = 0       ' reset for next 1 Min
     EndIf
   Case 2
     StepNbr = 3
   Case 3
     'StepNbr = 5                          'un-comment to quit after Step 3
 End Select                                'otherwise will run forever
End Sub
Sub WebInt
 Print "From Int. Routine"
 Print mm.topic$
 Print mm.message$
 If (mm.topic$ = "Control") AND (mm.Message$ = "Reset") then
   CPU-Restart
 EndIf
 StepNbr = 1
End Sub
'Program jumps here at start
 TimeGet                                   'get the latest time in mSec.
 TaskScan                                  'se which tasks need attention.
 If StepNbr = 5 Then exit do               'a way to exit program
WEB MQTT CLOSE                              '
Print "Run Time = ";mSec                    'time program has run for.
Print "Tot ziens"
End
Hervey Bay Qld.
pwillard
Posted: 06:12pm 20 Nov 2023
Thank You.
Dinosaur
Posted: 10:30pm 20 Nov 2023
Hi All
Correction:
  Case 1
      StepNbr = 2
    EndIf
Should be
  Case 1
    EndIf
    StepNbr = 2
Otherwise Case 1 would hog the time.
Hervey Bay Qld.
Dinosaur
Posted: 11:00pm 21 Nov 2023
Hi All
Now that I (think) I know how it all works, I have re-written to MQTT CLOSE after every transmission.
It only takes 25mSec to open a connection, Publish a message and then Close the MQTT.
Note that comments above code have been updated as well.
In some way holding the port open when not in use may have contributed to MMCC scrolling problem.
'---AmpHour.bas-----------------------------------------------------------------
'On Debian Bookworm
'   edit /etc/mosquitto/mosquitto.conf and add the following lines:
'   allow_anonymous true
'   listener 1883
'   Security = WPA/WPA2/WPA3 Personal,Enter Password,
'   IPv4 = Shared to other computers
'2: On Rpi-Pico
'     Step  0 Confirms (once) we can reach the Hotspot and then disconnects.
'     Step  1 Publishes (once) Time to Rpi-Zero (Pico has TC).
'     Step  2 Publishes (once) Pico's IP address (you can Ping from Zero)
'     Step  3 Publishes (reteadly) an incrementing TxValue.
'     Step  4 Start of your other code.
'   Purging mosquitto in Linux to re-install involves manually removing
'   the /etc/mosquitto folder.
'   Note: Haven't tested yet for how long the broker will hold onto message.
'         Because Clients are sending every 30 sec's, I check every 20 sec'c.
OPTION EXPLICIT
OPTION DEFAULT NONE
DIM AS STRING IP$,Tyd$
Dim as Float TxValue
Dim Integer CalTime,LoopTime,StartTime,BootTime,mSec,StepNbr,CommFlag
Dim Integer StartTime0,Delay0                 'variables for  each Task
Dim Integer StartTime1,Delay1
Dim Integer StartTime2,Delay2
Dim Integer StartTime3,Delay3
Dim Integer StartTime4,Delay4
 Print "Got Time"
END SUB
 Print Time$ ">";
End Sub
SUB Initialize
StartTime2 = mSec  'So that next delay is correct
StartTime3 = mSec  'So that next delay is correct
StartTime4 = mSec  'So that next delay is correct
TxValue = 50.0
End Sub
If mSec - StartTime0 >= 5000 Then         'Boot Pause.
EndIf
If mSec - StartTime1 >= 10000 Then         'allow Time Send.
EndIf
If mSec - StartTime2 >= 10000 Then          'allow IP send.
StartTime2 = mSec :Delay2 = 1
EndIf
If mSec - StartTime3 >= 30000 Then          'allow A/H send.
StartTime3 = mSec :Delay3 = 1
EndIf
If mSec - StartTime4 >= 60000 Then          'allow ?
StartTime4 = mSec :Delay4 = 1
EndIf
End Sub
Sub WifiConnect
 Print "Attempting Connection"
 WEB MQTT Connect "192.168.0.101", 1883,"Rpi-Hotspot","76216770",WebInt
 StartTime = mSec
 If MM.INFO(WIFI STATUS) > 0 Then Exit Do
 If mSec - StartTime > 30000 Then
     Print "CPU-RESTART ;";MM.INFO(WIFI STATUS)
     CPU RESTART
 EndIf
CommFlag = 1
End Sub
Select case StepNbr
If Delay0 = 1 Then
WifiConnect
If CommFlag = 1 Then              'If we are connected
       WEB MQTT CLOSE
       Print "Step 0 Success,wait for 10 Sec's"
StartTime0 = mSec :Delay0 = 0         'Cancel this step
       StartTime1 = mSec :Delay1 = 0         'refresh delay for next step.
StepNbr    = 1                        'Go Initialize MQTT
EndIf
If mSec - BootTime > 30000 Then        'If it's taking to long
CPU RESTART                'Reboot & try again
EndIf
EndIf
 Case 1                                  ' Time send; only once
If Delay1 = 1 Then
WifiConnect
Tyd$ = Time$
WEB MQTT PUBLISH "AmpHr",Tyd$ , 0 ,1
WEB MQTT CLOSE
     Print "Step 1 Time sent, wait for 10 sec's;";Tyd$
     StartTime2 = mSec :Delay2 = 0           'refresh delay for next step.
StepNbr    = 2
EndIf
Case 2                  'IP Addr send; only once
If Delay2 = 1 Then
WifiConnect
WEB MQTT PUBLISH "AmpHr",IP$,0,1
WEB MQTT CLOSE
     Print "IP Address sent, wait for 30 Sec's ;"IP$
     StartTime3 = mSec :Delay3 = 0           'setup delay for next step.
StepNbr = 3
EndIf
Case 3                                      'Repeat send incrementing value.
If Delay3 = 1 Then                        '30 Sec time is up.
WifiConnect
TxValue = TxValue + 0.1
WEB MQTT PUBLISH "AmpHr",Str$(TxValue) , 0 ,1
WEB MQTT CLOSE
     Print "A/H Updated ;";Str$(TxValue)
StepNbr = 4
EndIf
 Case 4
     StepNbr = 3
 End Select
End Sub
Sub WebInt
   CPU-Restart
 EndIf
End Sub
'Program jumps here at start of Boot.
CalTime   = Timer
 StartTime = Timer - CalTime
 BootTime  = StartTime
StepNbr   = 0
Print "Entering Wifi-Status Check"
Initialize
 Print "Wait for 5 Sec's for Step 0"
WEB MQTT CLOSE                              '
Print "Tot ziens"
End
Why does my Tab spacing get stuffed up here ?
Edited 2023-11-22 09:02 by Dinosaur
Hervey Bay Qld.
Posted: 12:58am 22 Nov 2023
  Dinosaur said  Why does my Tab spacing get stuffed up here ?
How would this web site know how many spaces you want a TAB to represent?
I use only spaces for indentation--TABs are likely to get messed up if you move the text to anywhere other than where it started out.
Dinosaur
Posted: 04:01am 22 Nov 2023
Hi All
  Quote  How would this web site know how many spaces you want a TAB to represent?
Good point. When I use Geany it converts for me, so will see if that is possible with MMEdit.
Otherwise, just before I post, load it into Geany.
Hervey Bay Qld.
Dinosaur
Posted: 08:25am 23 Nov 2023
Hi All
Tidied up and final before I start adding dedicated logic for my purpose.
Updated Nov 26 to fully working.
AmpHour.zip
Edited 2023-11-26 19:09 by Dinosaur
Hervey Bay Qld.
Dinosaur
Posted: 02:51am 09 Dec 2023
Hi All
Have an issue where MQTT on the Pico appears to transmit 16 characters,
but am receiving only 8 on the Rpi-Zero.
Can't work out if the problem is with MMBasic or FreeBasic on the Zero.
On the Pico:
           If CommFlag = 1 Then                  'If WiFiConnect succeeded
             TxStr = "C= " + Str$(TxValue) + ", mA = " + Str$(mAmps)
             On Error skip 1
             WEB MQTT PUBLISH "AmpHr", TxStr , 0 ,1
             If CommFlag = 1 Then If PFlag > 0 Then Print TxStr, Len(TxStr)
On The Zero end I am using Mosquitto with a statement like:
Open Pipe "mosquitto_sub --quiet -N --retained-only -t AmpHr -w 4" for input as #pf
   Input #pf, RxStr
Close #pf
Print RxStr + ";" + Str(Len(RxStr));
Which prints the first 8 Char's of the string and reports the string as 8 Char long ?
I have sent messages longer then 8, but as a single string between quotes.
Perhaps the embedded semicolon ?
EDIT: Either MQTT or Mosquitto at the other end doesn't like a comma in the string.
Edited 2023-12-09 15:11 by Dinosaur
Hervey Bay Qld.
Posted: 08:56am 09 Dec 2023
I expect the problem is:
Input #pf, RxStr
which in most BASICs will stop at the comma (in your example).
You may be able to use such as LINE INPUT (if it has it).
Edited 2023-12-09 18:57 by JohnS
Dinosaur
Posted: 09:48am 09 Dec 2023
Hi All
Good find John.
Not sure if Line Input will work with "Pipe" but will tests.
Hervey Bay Qld.
Posted: 10:57am 09 Dec 2023
You may (probably will) have to send a CR and/or LF
Or add another comma and then use input twice.
Dinosaur
Posted: 07:53pm 13 Dec 2023
Hi All
Just an update on this thread.
After updating the Pico to WebmiteV5.08.00b4 the performance has become more reliable.
It now survives the whole night sending messages every minute.
Basically I have a Zero W with an MQTT Broker and Client.
Transmissions published from the Pico are routed through the Broker to the Client on the Zero W.
The idea is to allow the Zero W to be switched OFF during the night (save current) and then in the morning start it again.
Every 3 min's the Pico goes looking for the Wifi with WEBSCAN Netscan%().
This causes a statement to be printed (out of my control) saying:
Performing WiFi Scan
If the Wifi is still off, then
If LInStr(NetScan%(),"Rpi-Hotspot") Then
fails and the Pico tries again in another 3 minutes.
After running all night, I simply turn the Wifi OFF on the Zero W and wait a few minutes and turn it ON again.
So, when the Wifi is ON, the Pico hangs(No heartbeat) with still only the Wifi Scan on the screen.
After about 5 minutes (typing this post) I pressed Ctrl C with no result.
So I turned the Wifi OFF again, thinking it may escape the loop.
A few minutes later I got
Not Found
and the command prompt.
This whole episode would have taken 15 minutes.
Would it have got there without me pressing Ctrl C ?
Worth noting that the Zero W never fails.
So I think there is still an issue with the WEB part but I can't identify what or where.
But at least now it can be chewed over by others.Hope there is enough detail.
EDIT:
When I simply pressed RUN to restart the program on the Pico, the following print statements
are executed at the beginning of the program, but it appears to hang on the SETPIN statements.
  Print "Var Restored    = ";BattCapacity
   Print "Got RTC         = ";Time$
   Print "Got Version     = ";MM.Ver
   Print "On platform     = ";MM.Device$
   Print "CPU Speed       = ";MM.Info(CPUSPEED)
   Print "Drive Capacity  = ";MM.Info(DISK SIZE)
   Print "Drive SpaceLeft = ";MM.Info(Free Space)
   Print "Nbr of Variables= ";MM.Info(VARCNT)
   If BattCapacity = 0 Then BattCapacity = 12000 'Coulomb = 200A  x 60 = 12,000
   SetPin GP18,CIN                               'we are counting Amp Hour pulses
   SetPin GP22,CIN                               'no option means Risng edge PULLDOWN
   Print "Finished setting Pins"
So then I have to repower.
Edited 2023-12-14 06:24 by Dinosaur
Hervey Bay Qld.
