Local Time 02:50 14 Sep 2026 Privacy Policy
Forum Index : Microcontroller and PC projects : WebMite - WiFi scannen ?
Pitt
Posted: 10:41pm 21 Nov 2023
Hello, I would like to come with you
WEB SCAN
When I start the program, I scan the existing WiFi accesses in the area. I can't do it because the WiFi first has to be started on the PICO with BASIC itself. How? Thanks for any help! Best regards Pitt from Cologne
Posted: 12:53am 22 Nov 2023
Begin with a usb/serial connection to the USB connector on the PicoWeb, using a terminal program such as TeraTerm. That gives you a ">" prompt in MMBasic (assuming that you have loaded the MMBasic WebMite firmware). From that prompt, you can issue MMBasic commands.
If that doesn't help you, you may have to explain your problem more fully.
