Local Time 00:01 14 Sep 2026 Privacy Policy
Forum Index : Microcontroller and PC projects : Forum Improvement: How can I help?
LeoNicolas
Posted: 05:01am 06 Dec 2023
Hello everyone
Is it possible to update the mobile forum view to have the image size from posts using the viewport width? Something like this:
img {
 max-width: 100vw;
PS: I couldn't find a parent class for applying the CSS only to the post images.
I can make the changes and provide a pull request if I can have access to the source code repo.
Posted: 09:29am 06 Dec 2023
  LeoNicolas said  Is it possible to update the mobile forum view to have the image size from posts using the viewport width? Something like this:
img {
 max-width: 100vw;
Try the "contact me" to ask Glenn in case he doesn't see your post.
LeoNicolas
Posted: 03:58pm 06 Dec 2023
No luck. The contact me link sent me to the about page which has several missing PHP include pages and no conact inormation.
Posted: 07:36pm 06 Dec 2023
  LeoNicolas said  No luck. The contact me link sent me to the about page which has several missing PHP include pages and no conact inormation.
Oh!
It used to work.
I will contact him and also PM you his email :)
LeoNicolas
Posted: 08:44pm 06 Dec 2023
Thank you John
Posted: 09:28pm 06 Dec 2023
I usually do some work on the forum over Christmas.
An issue with resizing the images down to fit the mobile screen is you will loose detail, especially in things like circuit diagrams. I'll do a few tests.
I am willing to share the forum source code, but would like a fellow php developer to go over it first to make sure there are no vulnerabilities in the code.
LeoNicolas
Posted: 11:05pm 06 Dec 2023
We can work with a pull request pipeline. Only reviewed code by the repo maintainers will be merged to the main branch.
This can ensure the code quality and security.
We can archive this with a private git repository with the main branch locked to direct changes.
I can help setting up something if necessary
Edited 2023-12-07 09:06 by LeoNicolas
LeoNicolas
Posted: 11:28pm 06 Dec 2023
  Gizmo said  I usually do some work on the forum over Christmas.
This change is only for mobile view and we can zoom in the image if we want to see more details or use the mobile landscape view. The current image size rendering on mobile doesn't work well
LeoNicolas
Posted: 05:27pm 11 Dec 2023
Hello Gizmo
What are your thoughts on having the code in a private GitHub repository and allowing us to create pull requests?
