Local Time 00:01 14 Sep 2026 Privacy Policy
Forum Index : Microcontroller and PC projects : WEBMITE HTML
TrevorW
Posted: 11:10pm 09 Dec 2023
response.zip
When I try to send the attached html file to my browser client, using the WEB TRANSMIT PAGE command, I get errors due to the style css content. I know the syntax is basically sound as I can open the file directly with my (Firefox) browser and the style description is correctly applied.
In particular the "padding: 3px" code line throws up an error "Padding: Different type already declared". If I remove the padding reference I yhen get an error from the button styling - "incorrect operator". Is the MMBASIC getting confused with the curly brackets used in the css content and those reserved for variables that are replaced by their r values?
Any assistance would be appreciated
Edited 2023-12-10 09:24 by TrevorW
Posted: 01:17am 10 Dec 2023
  TrevorW said  Is the MMBASIC getting confused with the curly brackets used in the css content and those reserved for variables that are replaced by their r values?
Yes, you need to use two opening curly brackets which will be converted to a single bracket for the browser.  You don't need to worry about the closing bracket.
For example:
.Device1{{
   padding:3px;
   color:black;
   background-color:{{BG1$};
   border:black 2px solid;
TrevorW
Posted: 03:03am 10 Dec 2023
For example:
.Device1{{
   padding:3px;
   color:black;
Thanks for the advice Geoff
Trevor W
