panky Guru Joined: 02/10/2012 Location: AustraliaPosts: 1134
Posted: 03:31am 22 Dec 2023
With the latest 5.07.03b22 when I enter LIST COMMANDS from the command line, MMB4W prints out all commands up to COPY then crashes - MMB4W locked up, unresponsive (both OLC window and terminal window). Hard shutdown and reload required.
If I set OPTION CONSOLE BOTH, I can see the output in the terminal screen up to the COPY command after which there is several screens worth of blank (null ?) characters.
All other LIST commands work OK - LIST FUNCTIONS, LIST PAGES etc. ( I'm on Mint running MMB4W under wine but as all other variations of the LIST command work, this should not be a factor?).
Doug.... almost all of the Maximites, the MicromMites, the MM Extremes, the ArmMites, the PicoMite and loving it!
