LeoNicolas Guru Joined: 07/10/2020 Location: CanadaPosts: 625
Posted: 07:41pm 05 Jan 2024
Hello everyone I think this is a question for matherp
The sprite show safe command has a parameter we can use to move the sprite to on top of the other ones. Is it possible to modify the same command to accept something like -1 and move the sprite to the bottom of the stack? This will be very useful for shadow sprites
matherp Guru Joined: 11/12/2012 Location: United KingdomPosts: 11834
Posted: 10:55pm 05 Jan 2024
No.This would require hiding all sprites first to re-order the stack. That isn't the way it works
