Forum Index : Microcontroller and PC projects : When a Pico W isn't a Pico W
| grumpyoldgeek Regular Member Joined: 30/07/2018 Location: United StatesPosts: 58 |
I bought a few very inexpensive "Pico W" modules on Aliexpress, loaded the Webmite firmware, and got this error "[CYW43] Failed to start CYW43". After some searching, found this page: https://forums.raspberrypi.com/viewtopic.php?p=2169643 It turns out that the module uses an ESP8285 to implement WiFi with an AT command protocol. Edited 2024-01-14 09:17 by grumpyoldgeek |
It was a good thing that they were "inexpensive ". Geoff Graham - http://geoffg.net |
| al18 Senior Member Joined: 06/07/2019 Location: United StatesPosts: 251 |
Thanks for the warning. I’ll stick to paying retail price $6 from Raspberry Pi distributors |
They run Picomite firmware. I'll find a use for them. |
