Local Time 20:55 13 Sep 2026 Privacy Policy
Forum Index : Microcontroller and PC projects : picomite feature request - CTS and RTS
Posted: 02:45pm 15 Jan 2024
hi Peter and Geoff,
   i'd like to make a feature request for the picomite, to make it possible from an mmbasic program to set and clear the console's CTS line, and to read the state of the console's RTS line.
a possible syntax would be:
option CTS 0
option CTS 1
i=mm.info(RTS)
i'm wanting to use this for out-of-band signalling between a picomite and a USB-attached terminal emulator, so that an mmbasic program can, for example, send a private message to a terminal emulator asking the emulator to retrieve the system time, and for the emulator to respond back to the mmbasic program with a private message containing the requested data.
the mmbasic program would assert CTS when it wanted to send a private message. the terminal emulator would respond by asserting RTS. when the mmbasic program saw RTS asserted it would send the private message and wait for the response. upon seeing the response it would clear CTS and wait RTS to be cleared, then carry on as normal.
rob   :-)
Edited 2024-01-16 00:48 by robert.rozee
Posted: 02:53pm 15 Jan 2024
Too specialised - so no.
