Local Time 16:55 13 Sep 2026 Privacy Policy
Forum Index : Microcontroller and PC projects : Picomite bootup time
apalert
Posted: 05:18am 26 Feb 2024
With Micromite Explore 28 I find time to bootup and run a program is a fraction of a second with either USB or battery power.
With my Picomite it takes about 2 seconds on USB power or 5 seconds on battery.
Does that seem normal?
Posted: 06:17am 26 Feb 2024
Yes.
With the PicoMite or PicoMite VGA, all of MMBASIC is stored in the external QSPI memory chip.  At boot-up, the 2040 chip copies key sections of the MMBASIC interpreter into the 2040's RAM, then starts the interpreter.
You need to wait a few seconds with the Pico-based ports, for the chip to "Boot" vs the PIC32-based ports of MMBASIC, which start instantly.
It is done this way, due to lack of memory resources on the RP2040 chip vs the memory available on the PIC32 series of chips.
Perfectly normal - and unavoidable, before you ask!
Posted: 08:01am 26 Feb 2024
Hello everyone - after a much needed break, I am back!!!
This ‘delayed’ startup time confused me at first but I was determined to solve it
If you enable the  Serial-Console option (ie as if you’re going to talk via an external usb-to-uart module), you’ll see the Pico start up almost instantly.
I can only assume the startup routine is looking for a confirmed console connection via the Pico’s usb port; you can see this ‘delay’ if your terminal app isn’t running when you connect the Pico to your computer (and the Pico is controlling some kind of visual or audible device so you know when it has eventually started).
I have several battery powered standalone Pico’s with  OPTION SERIAL CONSOLE …. set, and with the ability to  plug in an HC05 Bluetooth module should I need to program the Pico……
Hope this helps 👍
Posted: 08:48am 26 Feb 2024
hi WhiteWizzard.
   is really good to see you are back and ok.
rob   :-)
PhenixRising
Posted: 10:07am 26 Feb 2024
  WhiteWizzard said  after a much needed break, I am back!!!
Huh? A "break" for me is getting rid of people so that I can get back to playing with Mites
Really great to see you back
Posted: 10:11am 26 Feb 2024
Focussing on the original question; can I just confirm that my answer was related to a standard PicoMite - I have not tried this on the vga or web versions of the Pico.
Can anyone else confirm if setting OPTION SERIAL CONSOLE speeds up these boot times too (assuming they are also ‘delayed’ when not connected to a terminal app!)
apalert
Posted: 10:34am 26 Feb 2024
Thanks Grogster, good to know it wasn't my fault :)
Posted: 10:44am 26 Feb 2024
Hiya WW! Great to see you back. :)
apalert
Posted: 10:48am 26 Feb 2024
Yes, standard Picomite. It's a huge improvement, many thanks :)
With USB power it boots in well under 1 second. On batteries bootup seems to be now about 1 second. I can live with that, was planning for user to hold in rotary encoder switch 1 second to boot the device so will probably make my coding easier!
Posted: 10:58am 26 Feb 2024
  apalert said  Thanks Grogster, good to know it wasn't my fault :)
…..but do try setting OPTION SERIAL CONSOLE to speed it up (refer to the User Manual for the 2 (or3) required parameter values)
SORRY - messages crossed as my webpage hadn’t refreshed
Edited 2024-02-26 21:01 by WhiteWizzard
PhenixRising
Posted: 11:26am 26 Feb 2024
FWIW: ARMmite H7 is serial console and boots <1sec
H7 is
Posted: 11:29am 26 Feb 2024
Welcome back to the fold Phil,
Posted: 09:01pm 26 Feb 2024
I will have to have a play about with a Pico module now, cos it seems I might have put you crook!
My reply was pretty much a copy/paste of an answer to a similar question I asked a while back.
Put an LED on an I/O pin, write a single line of code to make that pin high.
Plug in the power to the Pico, time how long it takes for the LED to light - it's always been about six seconds for me....Pico OR PicoVGA.
Now I have to experiment!
Oh, and also fantastic to see you back on the forums WW - I think we all thought we had lost you to other projects and you might not be back, so good to see you back again.
cosmic frog
Posted: 12:20pm 27 Feb 2024
I've just tried this on a standed PicoMite and the boot up time is amazing.
OPTION SERIAL CONSOLE GP4,GP5,B
Dave.
ps. Welcome back Phil.
Posted: 12:50pm 27 Feb 2024
#ifndef USBKEYBOARD
   if(!(Option.SerialConsole==1 || Option.SerialConsole==2) || Option.Telnet==-1) while (!tud_cdc_connected() && mSecTimer<5000) {}
#endif
Posted: 06:37am 28 Feb 2024
WTF?!
This is why I refuse to deal with C....
Utterly confusing, syntax wise.
But again - that is only cos I don't code in C, cos I don't understand C.
Edited 2024-02-28 16:38 by Grogster
Posted: 08:33am 28 Feb 2024
  Quote  This is why I refuse to deal with C....
Basic C syntax maps 1:1 onto MMBasic
if NOT(Option.SerialConsole=1 OR Option.SerialConsole=2) OR Option.Telnet=-1) then do while ( NOT tud_cdc_connected() AND mSecTimer<5000) : LOOP
If there isn't a serial console or a telnet console specified then wait for a USB CDC connection for a maximum of 5 seconds
Edited 2024-02-28 18:35 by matherp
apalert
Posted: 08:58am 28 Feb 2024
  matherp said   If there isn't a serial console or a telnet console specified then wait for a USB CDC connection for a maximum of 5 seconds
So there is 5 second boot time on battery power cited in my original post.
Does the delay have to be that long? If booted from USB it is there from the get go so why not loop for say just 1 second?
Posted: 01:50pm 28 Feb 2024
Only guessing...
Probably because the three tests are very fast. Windows needs time to recognise an attached device before creating a virtual COM port and connecting to it. It may not be able to do that within a second.
Posted: 09:29pm 28 Feb 2024
Agreed.
And does indeed seem I was wrong and putting you crook on my first reply - sorry about that.
According to what has been discussed in this thread, if you define the console to some pins on the Picomite, then this delay is essentially elimionated completely - not to paraphrase an earlier post from another member that pretty much states the same thing.
I was unaware of this.
But now that I know, I think I will still just use as-is, cos it is really convenient to be able to use the 2040 USB VCP, and 5-6 seconds is of no concern - TO ME.
But I can see it might be a nuisance to some members, and so in that case, setup some console pins as part of the process, and things should start more-or-less instantly.
Good to know!
