Local Time 16:55 13 Sep 2026 Privacy Policy
Forum Index : Microcontroller and PC projects : USB version and my gamepad journey - an update
karlelch
Posted: 03:57pm 28 Feb 2024
here is an update about my search for USB firmware compatible controllers - see also my post in the PicoMite USB betas thread. Maybe this helps someone.
Finally, I got a wired controller working: An original wired Sony Dualshock 4 Controller PS4, it behaves as expected
I tried supposedly PS4 compatible wired (and wireless) controllers from Nacon (?) - neither of which registered with the PicoMiteUSB at all. Not recommended.
What I also tried (actually first) was a wireless PS3 compatible controller from EasySMX I still had lying around. This was where I found that it connects to immediately disconnect (see my post above). I tested it again and found out that one can set its compatibility with different systems (PS2, Windows, ...), however, none of the modes relayed all gamepad controls back to the PicoMite, mostly only one joystick and a button ...
Best
Thomas
