Local Time 16:55 13 Sep 2026 Privacy Policy
Forum Index : Microcontroller and PC projects : Question about OPTION KEYBOARD
Frank N. Furter
Posted: 11:37am 01 Mar 2024
I use a small USB keyboard where the keys share characters and numbers.
NUMLOCK is active by default. If I understand the manual correctly, I should be able to change this permanently with "OPTION KEYBOARD GR,0,0".
However, when I restart the computer, NUM is still active!?!
I can also neither switch SHIFTLOCK on nor off...
Am I doing something wrong???
I use version "USB Edition 5.09.00b2"
Frank
Posted: 12:00pm 01 Mar 2024
Wasn't implemented for USB keyboards
Try this
PicoMiteUSB.zip
Frank N. Furter
Posted: 12:25pm 01 Mar 2024
Peter, thank you very much!!!
You have removed UPDATE FIRMWARE and unfortunately the update mode cannot be forced via the TTL-USB converter when switching to 1200bps.
On my small computer, the BOOT button is unfortunately not accessible from the outside (the display is in the way). Do you know of any other way to force the update mode? Is there perhaps a POKE or something similar?
Frank
Posted: 12:35pm 01 Mar 2024
Frank
On the USB versions you have to use the BOOT button - no other way. Because the USB port is in host mode nothing else will work.
Frank N. Furter
Posted: 12:52pm 01 Mar 2024
Ok! That's a pity!
I have tried your version - the one with NUM now works.
...unfortunately the console output on the LCD no longer works after a restart.
These are my OPTIONS:
> option list
PicoMite MMBasic USB Edition  5.09.00b4
OPTION SYSTEM I2C GP6,GP7
OPTION COLOURCODE ON
OPTION KEYBOARD GR, 0, 0, 600, 150
OPTION CPUSPEED  252000 'KHz
OPTION LCDPANEL CONSOLE
OPTION DISPLAY 40, 100
OPTION LCDPANEL ILI9488, LANDSCAPE,GP15,GP14,GP13,GP2
OPTION TOUCH GP12,GP11,GP10
GUI CALIBRATE 0, 3969, 3900, -1228, -848
OPTION SDCARD GP22
OPTION AUDIO GP0,GP1', ON PWM CHANNEL 0
OPTION RTC AUTO ENABLE
Frank
Posted: 02:14pm 01 Mar 2024
Frank, please could you try again.
PicoMiteUSB.zip
It wasn't working for me either and all I've done is re-compiled and now it is
Frank N. Furter
Posted: 02:31pm 01 Mar 2024
Ok, this version now also works for me. Thank you very much!
P.S.: ...I'm just about to install a BOOT button...
Frank
