Local Time 14:05 13 Sep 2026 Privacy Policy
Forum Index : Microcontroller and PC projects : Need Help to Remember
OA47
Posted: 04:32am 22 Mar 2024
I am away from the shed at the moment so I can't refer to previous projects and I did a bit of trawling thru the forum but couldn't find an answer. Is it Ok to run an ILI9341 directly off the VBUS pin of the Pi-Pico if the 3T reg is not bypassed?
If so do I need a current limiting resistor to the backlight LED?
0A47
Posted: 05:40am 22 Mar 2024
It depends on the version. Older ones have the backlight LEDs going directly to the LED pin so require a resistor. Later ones have a transistor Q1 with a resistor to the LEDs and a 1kΩ base resistor so don't need it, but it won't hurt up to 10kΩ.
I think most people run them from 5V. Just look for Q1.
OA47
Posted: 09:11am 22 Mar 2024
Thankyou Phil, I put a 33R resistor in just in case.
0A47
