Local Time 13:20 13 Sep 2026 Privacy Policy
Forum Index : Microcontroller and PC projects : LCD Character Module with 4 x 40 Characters- 2 enables
jwettroth
Posted: 04:37am 26 Mar 2024
I'm making a low power terminal kind of gadget.  I got a single 4 line by 40 character LCD module that uses TWO HD44780 type controllers.  It looks to a system like two displays stuck together horizontally as two 4x20 panels.  The data lines and RS pin are all the same but there are two enables.  Is there a good way to handle this.  I can put a HC157 type mux on the EN and flip it and do right and left sides of display- this wouldn't be so bad.  Can the MX170 or MMBASIC support two text LCD panels?
ie- Can I instantiate this command twice? same d4-d7 and RS but different ens
LCD INIT d4, d5, d6, d7, rs, en1
LCD INIT d4, d5, d6, d7, rs, en2
What's the cleanest way to handle this.  I'm doing this on an PIC32MX170 (my favorite) initially but might want to use the pico.  Does mmasic support this on either device.
I'll post the final device.  I have fond memories of a TRS-80 M100 "notebook". Mainly want a mini terminal.
Thanks in advance for any help.
John Wettroth
Chopperp
Posted: 05:23am 26 Mar 2024
Hi
There's a post here on the subject.
The method I used many years ago and still working is at the bottom of the page.
Brian
ChopperP
Posted: 05:31am 26 Mar 2024
  Quote  ie- Can I instantiate this command twice? same d4-d7 and RS but different ens
I would be surprised if it works.
Try it, MMBasic will let you know one way or another.
Chopperp
Posted: 06:39am 26 Mar 2024
You need to do an LCD CLOSE before the next LCD INIT
ChopperP
jwettroth
Posted: 07:39pm 26 Mar 2024
Thanks Phil and Choperp- this is pretty clean and just what I needed.  Great buch as always.
John Wettroth
