Forum Index : Microcontroller and PC projects : PicoMite Driver for lcd panel using ST7789 controller
| morgs67 Regular Member Joined: 10/07/2019 Location: AustraliaPosts: 78 |
Purchased a LCD display marked 2.4" TFT SPI 240X320 v1.3. It is almost identical to the red board shown in the picomite manual headed "Example SPI LCD Panel Configuration". However, it does not use a ILI9341 controller. With the ILI9341 driver the display is in portrait mode with part of the screen unused. Tried several other drivers with no luck. Then found the ST7789_320 driver almost works. The orientation needs to be set to Reverse Landscape. But all the colours are inverted (red RGB(255,0,0)is blue RGB(0,255,255), green is purple and blue is yellow). The screen is white and the text black. BLIT and gui calibration both work OK. @matherp ,Peter is there any chance of adding an option to the ST7789_320 driver to cater for this version? Tony |
| matherp Guru Joined: 11/12/2012 Location: United KingdomPosts: 11830 |
OPTION LCDPANEL anyspidisplay orientation, dcpin, resetpin, cspin [,backlightpin] [,INVERT] set INVERT to invert the colours. Works on ILI9488 but may work on ST7789. Latest RC only Edited 2024-04-04 01:39 by matherp |
@matherp Using - PicoMite MMBasic Version 5.09.00RC3 Tested the following displays INVERT works on ILI9488 Does not work on- ILI9341 or ST7789_320 Footnote added 2024-04-04 09:38 by morgs67 link to item- https://www.aliexpress.com/item/32960241206.html |
Try this PicoMite.zip |
@matherp Peter, Tried your test invert, and success! This works on- ILI9488 ILI9341 and ST7789_320 confirmed on each by trying normal and invert. Thanks Tony |
