Forum Index : Microcontroller and PC projects : Mark on new LCD screen
I received a new LCD Display and the screen had a large blemish in the middle. I complained and the seller sent a video of how to fix and it is so simple. Others here may already know but I was amazed at how easy it was. I can't upload a video but you hold the screen between thumb and forefinger of both hands, top and bottom of the glass and squeeze hard. Two or three squeezes in different places and the mark was all gone. "It is better to be ignorant and ask a stupid question than to be plain Stupid and not ask at all" |
| phil99 Guru Joined: 11/02/2018 Location: AustraliaPosts: 3376 |
Thanks for letting us know. A very useful tip. |
This was the mark. "It is better to be ignorant and ask a stupid question than to be plain Stupid and not ask at all" |
| SimpleSafeName Guru Joined: 28/07/2019 Location: United StatesPosts: 351 |
Really? I'll (try :) ) to remember that trick. Thanks! |
Grogster![]() Admin Group Joined: 31/12/2012 Location: New ZealandPosts: 10037 |
Good to know! I'd only be worried about cracking the glass. It does not take much!!! ![]() Smoke makes things work. When the smoke gets out, it stops! |
| zeitfest Guru Joined: 31/07/2019 Location: AustraliaPosts: 701 |
Hmm... would that be a 3.2 inch display ? Not many local vendors around for them. I received one today, when it arrived the "sealed" antistatic bag had been cut open, it is not showing any display apart from the backlight. The adafruit lcd utility runs ok and reports back various parameters so I think the connections are OK. But nothing displays. Annoying to waste time on it when it should be a product without Hassle. Compressing a lcd is really not a good thing, they used to get dead pixels etc from damage. I would get a replacement, they are expensive enough. Edited 2024-04-08 18:10 by zeitfest |
It is not compressed as pushing on the glass, its squeezing the sides together. This is the video I was sent. video "It is better to be ignorant and ask a stupid question than to be plain Stupid and not ask at all" |
| Pluto Guru Joined: 09/06/2017 Location: FinlandPosts: 411 |
Thanks for the trick Palcal! pluto |
Maybe not such a simple fix, each morning the blotch is back and I have to fix again. "It is better to be ignorant and ask a stupid question than to be plain Stupid and not ask at all" |
Oh, gotcha - sounds much safer for the glass! ![]() Smoke makes things work. When the smoke gets out, it stops! |
