Local Time 12:28 13 Sep 2026 Privacy Policy
Forum Index : Microcontroller and PC projects : CMM2 Profiler
joker
Posted: 05:01pm 09 Apr 2024
Hello,
Some time ago I discovered that the CMM2 has a built-in profiler, which you can activate by typing "option profiling on" at the basic prompt.
I found this feature quite facinating so I tried to use it to optimize my games. Unfortunately the CSV output is not really human friendly and the advice from the manual to use Excel for the analysis is quite time consuming.
Therefore I wrote a small tool in Java (running on Windows and Linux) called CMM2Profiler, that makes life a bit easier here.
You can load a profiler log and do some basic analaysis. Screenshot below.
The source code is on GitHub but for all who don't want to compile the java code, I put a precompiled version in the GitHub Wiki:
  https://github.com/grimm-git/CMM2Profiler/wiki.
The archive contains two start scripts:
 - bin/app for Linux and
 - bin/app.bat for Windows
The only thing you have to add is a Java JRE 17 or above.
Best Regards
 Matthias
Edited 2024-04-10 03:02 by joker
PilotPirx
Posted: 07:50am 10 Apr 2024
Sorry, but I don't want to die stupid.
What is this feature used for? I haven't heard of it yet.
Posted: 08:09am 10 Apr 2024
It tells you how many times a specific Basic line is executed and how much CPU time that line uses. This allows you to tune performance of the application. Unfortunately, the mechanism uses a lot of memory so can't be copied to the PicoMite (before anyone asks   )
PilotPirx
Posted: 08:32am 10 Apr 2024
Thx, nice feature.
When I retire and write my first big program for the CMM2, I'll test it out (and the java tool).
toml_12953
Posted: 08:52am 10 Apr 2024
  joker said  Hello,
Best Regards
 Matthias
Thank you for a very useful utility!
Might I suggest giving the user the ability to sort on the different columns? I know I'd like to see the last column (Calls x Time) in decreasing order so I could determine the biggest "offenders" at a glance.
joker
Posted: 07:33pm 11 Apr 2024
Yes, you might
But it is already built in.
Just click on the column headers until you get the sort order you prefer.
Best Regards
 Matthias
LeoNicolas
Posted: 11:58pm 12 Apr 2024
This is something I will really use for optimize Knightmare
