Local Time 10:30 13 Sep 2026 Privacy Policy
Forum Index : Microcontroller and PC projects : OPTION LCDPANEL  VIRTUAL_C
Teo1
Posted: 12:59pm 01 May 2024
Hi all,
Can someone tell me how I can use this "OPTION LCDPANEL VIRTUAL_C" ?
Will it create a virtual display on your PC screen?
Can I see what I'm drawing?
Can I find an example of use somewhere?
Thanks in advance,
Teo
Posted: 01:09pm 01 May 2024
It allows you to create an image without a display connected and then you can save it to disk. The target use is for the WebMite to allow constructed images (E.g. graphs) to be embedded in web pages.
Edited 2024-05-01 23:10 by matherp
Teo1
Posted: 01:36pm 01 May 2024
Thanks for the reply ,
Please , can you send me an example ?
Thanks a lot,
Teo
Posted: 01:01am 02 May 2024
> OPTION list
PicoMite MMBasic Version 5.09.00RC3
OPTION FLASH SIZE 16777216
OPTION COLOURCODE ON
OPTION CPUSPEED  420000 'KHz
OPTION DISPLAY 55, 155
> list
'Make a virtual image - 320x240 4 bits/pixel
cls rgb(blue)
BOX 30, 20, 250, 150, 20, rgb(red), rgb(yellow)
CIRCLE 160, 120, 80, 10, 1.5, rgb(white), rgb(green)
TEXT 160, 120, "Test Image", "CM", 2, 2, rgb(magenta), rgb(myrtle)
save compressed image "Test Image.bmp"
> files "*.bmp"
A:/
00:21 01-01-2000       4472  Test Image.bmp
0 directories, 1 file, 15462400 bytes free
> xmodem s "Test Image.bmp"
On a WebMite you add the image name to a HTML so that it can be viewed elsewhere.
Or, as above use Xmodem to send it to an attached PC via a terminal program.
As the virtual display is the same as a PicoMiteVGA that is a good place to develop that part of your program.
In the WebMite manual see the section "Live Graphical Data in a WEB Page"
Teo1
Posted: 12:15pm 02 May 2024
Thank you very much,
Teo
