Local Time 09:26 13 Sep 2026 Privacy Policy
Forum Index : Microcontroller and PC projects : Bug with blit and NOTBLACK?
William Leue
Posted: 01:29pm 09 May 2024
I am running version 5.07 firmware on my CMM2 Gen 2. I am trying to draw some icons that I created by reading the images from a BMP file into an offscreen page, and then blitting the icons from the offscreen page to the current onscreen page.
I am using the &B100 optional argument to blit to suppress copying transparent pixels, which for me are black ones. My icons have some regions that I want to look black, so I am coloring those regions rgb(NOTBLACK). I checked and this seems to be working: the value of rgb(NOTBLACK) is 251666432.
However, when the icons are displayed, the NOTBLACK regions are being treated as transparent, so they do not appear.
I am guessing that the problem may be that when I created the BMP file originally using SAVE IMAGE, it did not correctly save the NOTBLACK regions, but made then true black instead. Or possibly the problem happened with the LOAD BMP command. I know that blit works correctly.
Any clues?
-Bill
William Leue
Posted: 02:22pm 09 May 2024
Ah, I found the problem! It turns out that in order to correctly save NOTBLACK to a BMP file and load it back in again from the file, you cannot use 8-bit colors. Changing to 16-bit colors with MODE 1,16 fixes it.
-Bill
stanleyella
Posted: 04:43pm 09 May 2024
