Local Time 08:10 13 Sep 2026 Privacy Policy
Forum Index : Microcontroller and PC projects : RPi Pico Clone with SD card slot
Canada_Cold
Posted: 08:21pm 23 May 2024
Hi, I saw these on the Digikey website when I was looking for some other parts.
https://www.digikey.ca/en/products/detail/groundstudio/RLJDMV-AAA/21080805
I was impressed with the look and the spects, so I ordered a couple to test with.
I received the boards yesterday and booted one up with 5.08.   I am very impressed with the quality of the boards.  There is a boot and a Reset button, power LED, LED on GP 25, a Green LED on the battery charging circuit, a SD card adapter, USB-C connector and  8MB External QSPI FLASH memory.  It also lists “Voltage regulator 2x ME6211C33U4AG-N (ADC reference and power supply)”
I don’t know if anyone else has tested these.   I like to idea of having a onboard SD card slot.
The boards are $11.59 CAD or about $8 USD from DigiKey.
https://ardushop.ro/en/home/2652-marble-pico.html
Sorry, I wanted to include a picture of the board, but I couldn't find how to do that.
Posted: 09:29pm 23 May 2024
The Data sheet has a pic and circuit diagram. That's a creditable start!
If you want to try it with VGA then you'll have to specify the VGA pins as they clash with the SD card.
That's a linear regulator. Yep, the ADC REF has its own regulator. It might reduce noise a bit but it won't fix the ADC problem.
Posted: 10:32am 24 May 2024
  Canada_Cold said  I wanted to include a picture of the board
Click the tree+up_arrow icon to upload (second from the right above the edit text box). If you don't have the image as a jpg on your computer, take a screen shot, edit to clip what you want (e.g., with paint), save as jpg, and then upload.
Edited 2024-05-24 20:34 by lizby
Canada_Cold
Posted: 02:31pm 24 May 2024
Hi Lizby,
Thanks for the help, I'll give that a try.
Don
Canada_Cold
Posted: 05:12pm 24 May 2024
Hi Mick,
I have not tried the ADC, but I do understand there are some issues with the ADC on the original RPi board. I think if I needed an ADC in a project, I would more likely to use an external part.
Thanks, Don
mclout999
Posted: 06:50pm 27 May 2024
Clickable links. =
