Local Time 06:55 13 Sep 2026 Privacy Policy
Forum Index : Microcontroller and PC projects : Colors inverted
Teo1
Posted: 10:35pm 07 Jun 2024
Hi everyone,
I want to use this display "https://www.buydisplay.com/lcd-5-inch-ips-ssd1963-tft-module-touch-screen-display-800x480-mcu-arduino" and I found that it has the RED and BLUE colors inverted.
There is a possibility of reversing these colors using PICOMITE ?
Thanks in advance,
Teo
disco4now
Posted: 11:36pm 07 Jun 2024
It could be in the lastest Picomite RC3 version as
OPTION LCDPANEL SSD1963_5ER_16 ,orientation
I noticed it while looking at the source, so just not documented in the manual as yet.
That is using it in 16bit mode.
8bit mode does not seem to be there so if not this may work.
Gerry
Edited 2024-06-08 09:43 by disco4now
F4 H7FotSF4xGT
Teo1
Posted: 06:51am 08 Jun 2024
Thank you for your answer!
But, which GP do I use for the D8-D15?
Thank you,
Teo
Posted: 07:58am 08 Jun 2024
I'm not sure if SSD1963 displays are supported in 16-bit mode on the PicoMite. It's very wasteful of precious GP pins. You may have to stick to 8-bit mode, in which case just leave DB8-DB15 floating.
disco4now
See this thread for 16bit It will need the special board described there.
To use 8bit you will have to see if peter will enable the SSD1963_5ER display. You could try the POKE DISPLAY commands I linked to above in the meantime. They may/should swap RED/ BLUE.
F4 H7FotSF4xGT
Posted: 08:12am 08 Jun 2024
Drat! I'd forgotten that! :)
I must be getting ancient....
Teo1
Posted: 09:26am 08 Jun 2024
Hi
Unfortunately "SSD1963_5ER" is inactive and I can't find any command for SSD1963
that reverses red with blue.
If you have any ideas, I appreciate it very much.
Teo
disco4now
Posted: 10:39am 08 Jun 2024
Get it working with SSD1963_5 or SSD1963_5A with red blue reversed, then
use the matching command below to fix the colours.
POKE DISPLAY &H36,&H08               Landscape
POKE DISPLAY &H36,&H58               Portrait
POKE DISPLAY &H36,&H38               RLandscape
POKE DISPLAY &H36,&HB8               RPortrait
You may be able to put the POKE command in MM.STARTUP to automate it.
F4 H7FotSF4xGT
Teo1
Posted: 10:55am 08 Jun 2024
Now it's OK
Thank you very much!
Teo
