jovian Regular Member Joined: 16/04/2017 Location: AustraliaPosts: 63
Posted: 03:08am 08 Jun 2024
Hi all Just wanted to report what appears to be a bug in webmite 5.09 This has been messing me up for days.. functions that run perfectly in main program but when library saved pull up errors. I have distilled the problem down to the following code. Once library saved, the function always gets truncated after the if...endif statement (regardless of what becomes before or after). Note there is no "next i" statement after library list all. I am finding that some functions are saving no problem and others are pulling up unexplainable errors. The length of the function is not a factor.
Can someone else replicate this behaviour?
library delete > > autosave
function dtn(d$)
local excelStartYear=1900 local i local deltaDays local ddd,mmm,yyy yyy=val(right$(d$,4))
For i=excelStartYear To yyy-1 If i Mod 4=0 and i Mod 100<>0 and i Mod 400<>0 Then deltaDays = deltaDays + 366 Else deltaDays = deltaDays + 365 End If next i
End function Saved 352 bytes > library save Library Saved 232 bytes > > library list all Function dtn(d$) Local excelStartYear=1900 Local i Local deltaDays Local ddd,mmm,yyy yyy=Val(Right$(d$,4)) For i=excelStartYear To yyy-1 If i Mod 4=0 And i Mod 100<>0 And i Mod 400<>0 Then deltaDays = deltaDays + 366 Else deltaDays = deltaDays + 365 End If > > ? mm.info(version) 5.09
Thanks Joe
Posted: 03:29am 08 Jun 2024
Comment out a few lines and the function saves fine:
function dtn(d$)
local excelStartYear=1900 local a local deltaDays local ddd,mmm,yyy yyy=val(right$(d$,4))
For a=excelStartYear To yyy-1 ' If a Mod 4=0 and a Mod 100<>0 and a Mod 400<>0 Then ' deltaDays=deltaDays+366 ' Else ' deltaDays=deltaDays+365 ' End If next a
End function Saved 367 bytes > library save Library Saved 132 bytes > > library list all Function dtn(d$) Local excelStartYear=1900 Local a Local deltaDays Local ddd,mmm,yyy yyy=Val(Right$(d$,4)) For a=excelStartYear To yyy-1 Next a End Function >
Rewrite the same few lines and the problem returns:
function dtn(d$)
local excelStartYear=1900 local a local sum local deltaDays local ddd,mmm,yyy yyy=val(right$(d$,4))
For a=excelStartYear To yyy-1 sum=365 if a Mod 400=0 Then sum=366 If a Mod 4=0 Then if a Mod 100<>0 Then sum=366 end if deltaDays=deltaDays+sum next a
End function Saved 373 bytes > library save Library Saved 212 bytes > > library list all Function dtn(d$) Local excelStartYear=1900 Local a Local sum Local deltaDays Local ddd,mmm,yyy yyy=Val(Right$(d$,4)) For a=excelStartYear To yyy-1 sum=365 If a Mod 400=0 Then sum=366 If a Mod 4=0 Then If a Mod 100<>0 Then sum=366 End If : >
phil99 Guru Joined: 11/02/2018 Location: AustraliaPosts: 3376
Posted: 04:45am 08 Jun 2024
Perhaps "End If" is being read as "End"
Try "EndIf" Removing the space might remove the confusion, though either should work.
Posted: 05:08am 08 Jun 2024
UN. FREAKIN.BELIEVABLE
That worked.
So it IS a bug then! "End if" is not legit in the Library WTF!!?
Yes thank you Phil that has put me out of three solid days of absolute misery... I have always used "End If" without problem but only just started using the Library... this has thrown so many stupid errors at me I have aged.
Thanks 1000000
Joe
matherp Guru Joined: 11/12/2012 Location: United KingdomPosts: 11830
Posted: 07:45am 09 Jun 2024
Thanks for the report - will fix in RC6
Posted: 02:37am 11 Jun 2024
You are a star (and a genius). Thank you.
Is there a way to donate support$?
Posted: 07:35am 11 Jun 2024
You should find the problem is fixed in the RC5 update I posted yesterday. Please check and confirm. The pleasure is in seeing you all use my/Geoff's code. Monetary recompense is not needed or a motivation.
Posted: 01:50am 14 Jun 2024
Hi Peter I can only say thanks for your generosity, it is making the world a better place. I have checked the RC5 update briefly, unfortunately nothing is running, here is a log:
WebMite MMBasic Version 5.09.00RC5 Copyright 2011-2024 Geoff Graham Copyright 2016-2024 Peter Mather
