Local Time 05:55 13 Sep 2026 Privacy Policy
Forum Index : Microcontroller and PC projects : GPS Module Antenna Orientation
Chopperp
Posted: 03:05am 30 Jun 2024
Quick question.
Does the photo below show the correct mounting (metal side up) orientation for these types of GPS antennas?
I've been mounting them with the ceramic(?) side up & they work OK.
Brian
ChopperP
palcal
Posted: 03:28am 30 Jun 2024
Interesting, I always use with ceramic side up.
Posted: 06:42am 30 Jun 2024
Not a very good image so it is hard to see the antenna, but essentially the ceramic side (ie, the antenna) should be pointing to the sky.  Having said that I have a number of installations where the antenna is pointing to the horizon and they seem to work just as well.
Chopperp
Posted: 11:20am 30 Jun 2024
Thanks for the replies.
I thought I had it right. Found another (clearer) image to confirm.
I too have one mounted vertically under a southern facing eave. Works OK
Brian
ChopperP
