Local Time 04:58 13 Sep 2026 Privacy Policy
Forum Index : Microcontroller and PC projects : ILI9341 MISO Pin
asknik2022
Posted: 02:16pm 11 Jul 2024
I have been told in the past that not all ILI9341 displays have the MISO Pin connected properly and that you need this Pin to use BLIT Commands in MMBasic
Is this true and if so how do I know which Displays actually have the MISO pin wired correctly.
Is there some tst code to check etc or a list of recommended manufacturers etc
stanleyella
Posted: 04:02pm 11 Jul 2024
some give spec. https://www.aliexpress.com/item/1005003943508410.html?
if it has the touch chip then miso probably wired.
Posted: 04:22pm 11 Jul 2024
AFAIK the ILI9341 is the one that works ok with everything.
The ILI9488 is the one that has problems with MISO.
stanleyella
Posted: 04:48pm 11 Jul 2024
  Mixtel90 said  AFAIK the ILI9341 is the one that works ok with everything.
I got four ili9341, different physical size but all 320x240 and miso is wired on all ie read screen pixel works.
one board did not have the touch chip.
the ili9488 needs the Schottky diode and resistor fix then works ok, screen read, touch, sd card.
asknik2022
Posted: 07:17am 12 Jul 2024
Is there a test program?
Posted: 08:35am 12 Jul 2024
This will test MISO by reading a pixel from the LCD screen. Copy and paste the two lines to the console.
'A 2 line colour counter.
> clear : option base 0 : dim string s(2)=(" blues"," greens"," reds") : dim integer a, b, c, d
> for a=0to 2:b=0:for c=0to 255:d=c<<a*8:pixel 9,9,d:if d=pixel(9,9)then:inc b:endif:next:?b;s(a):next
64 blues
64 greens
64 reds
If MISO is working properly the output is:-
ILI9488   64, 64, 64
ILI9341   32, 64, 32
PicoMiteVGA  2, 4, 2
OPTION LCDPANEL VIRTUAL_C  2, 4, 2
If you get those results Blit and Save Image will also be ok.
In program form:-
'A display colour counter
Clear : Option Base 0
Dim String S$(2) = (" Blues", " Greens", " Reds")
Dim Integer a, b, c, d
For a = 0 to 2 'cycle through blue , green and red
 b = 0        'initialize colour count
 For c = 0 to 255 'set the brightness
  d = c << (a * 8) 'make a 24bit colour
  Pixel 9, 9, d    'send it to a pixel
  If d = Pixel(9, 9) Then  'read that pixel back from the screen
   Inc b  'if the colour is the same as the one sent count it
  EndIf
 next
 Print b; S$(a) 'show  counted colours
next
End
More info here.https://www.thebackshed.com/forum/ViewTopic.php?TID=16834&P=10#223571
Edited 2024-07-13 12:06 by phil99
