Local Time 01:58 13 Sep 2026 Privacy Policy
Forum Index : Microcontroller and PC projects : Mixtel90 Here is Vindication
Rickard5
Posted: 07:10am 19 Jul 2024
Man you were Talking about how Useless the idea of an Arduino form factor picomite was, but you did it for me anyway :) and I guess I'm not the only one that finds Value in an Arduino Formfactor Picomite
Rick
Posted: 07:40am 19 Jul 2024
Copycats.
I stick by my argument though. It's a stupendously awful mechanical design for a hobbyist experimenter. They seriously broke the whole concept and there's no going back now. PCB components and connections have been on a 0.1" grid for a generation, why screw it up? I'm almost tempted to think that the person laying it out was inexperienced and made it "look right" without checking that it worked properly.
The Raspberry Pi is also a pretty stupid mechanical design to my mind simply because there are few ways to use a twin row GPIO port without using a PCB. However, the Raspberry Pi is designed as a computer with an add-on GPIO port and not as an embedded controller. The concept is different so there are mitigating circumstances.
zeitfest
Posted: 08:50am 19 Jul 2024
The story goes, it was originally designed as a simple device to be used in teaching sessions, deliberately designed with a different spacing so that the boards would not fit other systems and thus not go "missing" so much, ha ha..
Posted: 09:13am 19 Jul 2024
That's quite possible, or it might equally well be a fabrication to cover up incompetence. lol I'm not sure that the "going missing" would have been affected much by a non-standard pin spacing though. If they'd wanted that it would have been better to make it A4 size. :)
stanleyella
Posted: 03:50pm 19 Jul 2024
  Rickard5 said  Man you were Talking about how Useless the idea of an Arduino form factor picomite was, but you did it for me anyway :) and I guess I'm not the only one that finds Value in an Arduino Formfactor Picomite
Rick
I could use a board like that with vero/strip board as a hat, if the sockets are same pitch as rpipico board. I can see an ili9341 on strip board and the board plugging in but soldering a row of pins to the UNDERSIDE of stripboard is more effort than the component side.
If £10 I'd be happy.
stanleyella
Posted: 04:28pm 19 Jul 2024
just found this
https://www.aliexpress.com/item/1005006359298518.html?
Posted: 04:32pm 19 Jul 2024
I'va already designed the ArduinoMite_S, which is a PicoMite-based near-Arduino with everything including the fixing holes on a 0.1" grid. It's ideal for expanding with stripboard and padboard "hats". Probably best used with double-sided padboard.
No use to you because it's a pcb of course. ;)
pwillard
Posted: 05:18pm 19 Jul 2024
  Quote  That's quite possible, or it might equally well be a fabrication to cover up incompetence
This is the story I stick with when anyone asks... and I do remember that they DID admit to having an OOPS moment... but so many boards were fabricated they just stuck with the error and called it a feature.
Edited 2024-07-20 03:18 by pwillard
