Local Time 01:59 13 Sep 2026 Privacy Policy
Forum Index : Microcontroller and PC projects : LINE AA statement question
ville56
Posted: 02:57pm 26 Jul 2024
I am trying to draw a pointer, emulating a meter, with LINE AA and a line width > 1. As long as the line is not oriented parallel to either x or y axis, the line width is as specified in the statement. In case the line is parallel to x or y axis it is always only 1 pixel. Is there something i forgot to obey? In fact the behavior of line width is exactly the opposite as in the LINE statement as per manual. As LINE only obeyes line width for lines parallel to an axis. And i do not want to switch between LINE and LINE AA depending on the orientation of the line. The routine is time critical.
Version is PicoMite 5.09.00RC5
Display is ILI9341, Landscape
Many thanks for any advice,
Gerald
73 de OE1HGA, Gerald
stanleyella
Posted: 03:09pm 26 Jul 2024
line xstart,ystart,xend,yend,,colour
the line width is between yend and colour and is default ie 1 pixel
ville56
Posted: 03:51pm 26 Jul 2024
this is not quite what i'm dealing with .... i'm using:
line AA xstart,xend,ystart,yend,LINEWIDTH,colour
and this is drawing lines with the specified LINEWIDTH only of the lines are diagonal. Lines 0/180 or 90/270 degrees (parallel to the axis system) are always 1 pixel wide. I expected to have the lines always drawn LINEWIDTH wide no matter what the angle of the line is.
Posted: 05:06pm 26 Jul 2024
Try this. I've removed some validation code that I have got no recollection as to why it was there.
PicoMite.zip
ville56
Posted: 05:50pm 26 Jul 2024
Peter,
thanks a lot. This solved the problem.
And thank you again for this incredible piece of work.
Gerald
