Forum Index : Microcontroller and PC projects : last WebMite RC where?, idea and my problem
| homa Guru Joined: 05/11/2021 Location: GermanyPosts: 686 |
Hi Peter, 1) Where can I find the latest "official" RC for WebMite V5.09.00? On https://geoffg.net/webmite.html it is the RC5 from the date 26.06.2024. In your screenshot I already saw RC7. 2) The command PIO assemble 1,".end program list" shows the HEX values. Could you also show the values in binary behind it? Then it would be easier to compare with the information in the raspberrypi manual. Thanks in advance. 3) I am currently having problems with the "PIO WRITE" and understanding the data flow: MMBasic -> FIFO -> OSR -> PIO (or pins) in the current version "WebMite MMBasic Version 5.08.00". OUT does not do what it is supposed to do in my opinion and therefore I would like to test the current beta and the additional output in binary would be the dream. See also my question here: https://www.thebackshed.com/forum/ViewTopic.php?FID=16&TID=17155#225008 Matthias |
| Plasmamac Guru Joined: 31/01/2019 Location: GermanyPosts: 620 |
https://www.thebackshed.com/forum/ViewTopic.php?FID=16&TID=16834 Plasma |
Thanks, I know the thread. However, this is Peter's last entry on page 12. And it is only for the PicoMIte, not the WebMite. Hence my question about an exact link. https://www.thebackshed.com/forum/ViewTopic.php?TID=16834&P=12#224292 |
