Forum Index : Microcontroller and PC projects : could mmb be compiled?
| matherp Guru Joined: 11/12/2012 Location: United KingdomPosts: 11830 |
If you write a compiler for it |
oops messed up. was going to say used great cow basic and it's got a compiler so produces fast code for 8 bit. but would a mmbasic "compiler" make it faster? |
| PeteCotton Guru Joined: 13/08/2020 Location: CanadaPosts: 653 |
I'm of the mindset that it wouldn't make as much of an impact as you might think (but I could be wrong). If you're talking about games, then sure it would speed up the loops and if statements, but the bulk of the time in a game loop is copying graphics between memory locations, rotating them etc. Those are already written in highly efficient compiled/machine code. Most other intensive tasks (enemy AI) can be split over multiple game loop iterations. If it's for very fast I/O, then chances are that you will want more granular control over the timing than a compiler would allow for. |
| Mixtel90 Guru Joined: 05/10/2019 Location: United KingdomPosts: 9119 |
It could be compiled if you rewrote most of it from the bottom up, I suppose. I doubt if there's any other way as it was written purely as an interpreter. If you absolutely *have* to have some lightning fast sections then you cam use (well commented) CSUBs. ;) Remember that even compiled programs usually spend lots of time waiting for something to happen. They just do nothing faster. :) Mick Zilog Inside! nascom.info for Nascom & Gemini |
| PhenixRising Guru Joined: 07/11/2023 Location: United KingdomPosts: 2076 |
I think the nearest you can get is B4R, part of the B4X suite. They're doing ESP and there has been a limited amount of Pico stuff. I haven't checked in a while. Basic syntax but kinda event driven which I have never really taken to. |
| JohnS Guru Joined: 18/11/2011 Location: United KingdomPosts: 4378 |
Some parts would be "awkward", such as EVAL & EXECUTE. Others would stretch a lexer/parser. And... why do it? John |
