Forum Index : Microcontroller and PC projects : Grid
| Teo1 Regular Member Joined: 06/05/2023 Location: RomaniaPosts: 41 |
I think adding a grid would be useful for easy positioning and alignment of the graphics elements on the TFT surface. Thanks in advance, Teo |
| Mixtel90 Guru Joined: 05/10/2019 Location: United KingdomPosts: 9119 |
Squared paper and a pencil has worked well for me in the past. :) Mick Zilog Inside! nascom.info for Nascom & Gemini |
| PhenixRising Guru Joined: 07/11/2023 Location: United KingdomPosts: 2076 |
Prototype in Paint.net or similar? |
| lizby Guru Joined: 17/05/2016 Location: United StatesPosts: 3877 |
Easy enough to program: CLS x_span=10 y_span=10 For i=0 To MM.HRes/x_span For j=0 To MM.VRes/y_span Pixel i*x_span,j*y_span,RGB(white) Next j Next i Change x_span and y_span to whatever you want. PicoMite, Armmite F4, SensorKits, MMBasic Hardware, Games, etc. on FOTS |
Thank you all ! Teo |
