Local Time 06:56 12 Sep 2026 Privacy Policy
Forum Index : Microcontroller and PC projects : structured programming using cmm2 load and cmm2 run
andreas
Posted: 07:26pm 16 Dec 2024
On page 101 of the user manual there are commands "CMM2 LOAD" and "CMM2 RUN" described which allow the use of CMM2 *.inc files on a pico. I like that feature very much, but the files in RAM look a little "flat" and have funny Comment ticks ' on each line.
Example: part of a code of a larger .inc file
Option BASE 1'
Function SUM(A%,B%)As INTEGER'
If B% <A% Then'
Print "error in function sum(a%,b%): b% < a%"'
End '
Else '
SUM =(B%-A%+1)*(A%+B%)/2'
End If '
End Function '
Normaly I indent to show the program structure - so it looks a little ugly in my eyes. Is it a must have or is some pretty printing possible?
-andreas
Edited 2024-12-17 05:28 by andreas
twofingers
Posted: 10:56pm 16 Dec 2024
  andreas said  On page 101 of the user manual there are commands "CMM2 LOAD" and "CMM2 RUN" described ...
-andreas
Hi Andreas, could that be the reason? The Manual says:
  Quote  It is important to note that if used all editing of programs
must be offline or direct to and from disk as the source files cannot be
reconstructed from the version loaded by these commands.
Michael
The lone and ...
andreas
Posted: 07:27am 17 Dec 2024
-andreas
Michael
Hi Michael,
yes - for sure   I read this but had some hope that a guru has possibilities...
At least one can load and run programs that use #include but this way it is not very good usable for development.
-andreas
Posted: 08:14am 17 Dec 2024
[GUESSWORK]
The files look partially crunched. Probably because the file in flash will be treated similarly so that #Include and #Define can be used. I doubt if there's a way round it as it will all have to be in the same format prior to tokenisation (if that happens). As the manual says, you can't get the source file back as - at a minimum - all unnecessary spaces and comments are stripped out.
[/GUESSWORK]
twofingers
Posted: 11:37am 17 Dec 2024
  andreas said  ... yes - for sure   I read this but had some hope that a guru has possibilities ...
Hi Andreas,
ach so! (oh I see!)
I think that the design doesn't intend for this to be edited with the internal editor.
Michael
The lone and ...
Posted: 12:44pm 17 Dec 2024
If you want to work like this it is easy as long as you discipline yourself
ALWAYS
Use EDIT fname$
use CMM2 RUN fname$
Never
Use LOAD
Use EDIT
Probably avoid
CMM2 LOAD
RUN
