Local Time 06:22 12 Sep 2026 Privacy Policy
Forum Index : Microcontroller and PC projects : Help needed with rotary encoder click
OA47
Posted: 09:48pm 25 Dec 2024
Can someone help me with PLAY TONE values to give a click sound for a rotary encoder background sound on a picomite program?
0A47
Posted: 10:27pm 25 Dec 2024
For tick sounds you can use a DOUT and PULSE GPx,2 to deliver a tick to to the amp input via a small capacitor. The best value depends on the amp input impedance. Start with 100nF.
You may be able to avoid using a GPIO pin by connecting the capacitor directly to one of the rotary encoder outputs.
Or perhaps use 2 caps. - one to each encoder pin.
