Local Time 06:23 12 Sep 2026 Privacy Policy
Forum Index : Microcontroller and PC projects : Pico with Rotary Encoder + SSD1309
asknik2022
Posted: 08:58am 28 Dec 2024
asknik2022
Posted: 09:00am 28 Dec 2024
If i use a pi Pico which has a micro usb connector then the push button on the encoder connected to GP1 works fine but if I use the same code on a pi Pico with has a USB C connector it works fine until I push the button on the encoder and then it just freezes.
Any suggestions
Posted: 09:15am 28 Dec 2024
Not enough information, I'm afraid.
Version of MMBasic?
What is the "Pi Pico" with a USB C connector? There aren't any, only clones.
How is the encoder connected?
Sample of the code you are using?
