Local Time 11:25 11 Sep 2026 Privacy Policy
Forum Index : Microcontroller and PC projects : is there a simple bitmap format ?
zeitfest
Posted: 11:02am 01 Jan 2025
Is there a very simple bitmap file structure ? I thought a bmp file would be trivial to create but now I see there are quite a few additional fields etc.
Just after something that a program can write to a sd card and then allow a quick visual check in windows.
Posted: 11:14am 01 Jan 2025
ppm ascii files followed by ppm binary are probably the easiest. See here
jirsoft
Posted: 09:48pm 08 Jan 2025
BMP save is here as well...
GRF.lib
Jiri
