Local Time 11:25 11 Sep 2026 Privacy Policy
Forum Index : Microcontroller and PC projects : Pico PWM question
apalert
Posted: 09:53am 04 Jan 2025
Struggling to get channel B working on a pico. Wanting to use pin 12 which is PWM4B. In the following code, entered at the console prompt, pin 11, which is PWM4A, works fine. Pin 12 I come to grief!
> setpin 11, pwm
> pwm 4, 100, 50
> pwm 4, off
> setpin 12, pwm
> pwm 4, 100, 50
Error : Pin not set for PWM
> pwm 4b, 100, 50
Error : Expression syntax
Appreciate if someone can put me out of my misery :)
Posted: 09:59am 04 Jan 2025
From the manual
  Quote  PWM channel, frequency,[dutyA][,dutyB][,phase][,defer]
So if I don't want dutyA but do want dutyB it becomes
PWM channel, frequency,,dutyB[,phase][,defer]
apalert
Posted: 10:23am 04 Jan 2025
Awesome, thanks Peter
I did read manual I promise, just too dense to figure it out! Your example was a great help.
Canada_Cold
Posted: 11:46am 04 Jan 2025
apalert,
I worked on a project last fall that required a PWM output.   I found the following post Very helpful.
"PWM out, need some examples, not working for me."
https://thebackshed.com/forum/ViewTopic.php?TID=16947&PID=221685#221685
Don
apalert
Posted: 03:24am 05 Jan 2025
  Canada_Cold said  apalert,
Don
Thanks Don
