Forum Index : Microcontroller and PC projects : Is it possible to run mmbasic on stm32f4discovery
| Peter63 Senior Member Joined: 28/07/2017 Location: SwedenPosts: 205 |
Is it possible to run mmbasic on stm32f4discovery ? ![]() /Peter63 |
| Mixtel90 Guru Joined: 05/10/2019 Location: United KingdomPosts: 9115 |
I suspect it might, using MMBasic for the ArmMite. The VET6 on that has 512K ram, the VGT6 has 1M RAM. However, that board might have things connected to pins that are allocated to something else on the ArmMite. NOTE: Although it might run it may not support anything on the board! . Edited 2025-02-02 04:16 by Mixtel90 Mick Zilog Inside! nascom.info for Nascom & Gemini |
Thanks for the answer/Mick There is micropython for stm32f4, which I might try. Anyone who has tried programming stm32f4 in another way? ![]() /Peter63 |
