Local Time 07:57 11 Sep 2026 Privacy Policy
Forum Index : Microcontroller and PC projects : RP2040-zero. What Firmware do I program it with
Glen0
Posted: 07:11am 02 Feb 2025
I don't know what Firmware to use on the the RP2040-zero.
Also, what device should I select when using the Maximite Control Centre to program them.
Posted: 07:22am 02 Feb 2025
It depends on what you intend to attach.
PicoMiteRP2040V6.00.02b6.uf2 is the basic version and includes drivers for a variety of SPI and I2C displays.
For the others the name of the .uf2 file explains what it does.
In MMCC choose the closest match to the firmware you have chosen.
Edited 2025-02-02 17:26 by phil99
Glen0
Posted: 07:43am 02 Feb 2025
Thanks, I didn't know the zero uses the same FW as the Pico. It seems to be working ok.
Posted: 08:08am 02 Feb 2025
The RP2040-Zero is identical to the basic PicoMite, it just has less GPIO pins. I've used quite a few of them now. Good board.
Posted: 11:59pm 02 Feb 2025
Yes, I use the Zero module in a few of my projects now too.  Especially where I need compactness or there is not much PCB space.  They work well - have never had a dud one yet, despite their very cheap price.
