Local Time 05:43 11 Sep 2026 Privacy Policy
Forum Index : Microcontroller and PC projects : CJMCU-531 Time of flight module
foxleyboy
Posted: 10:47am 23 Feb 2025
Does anyone have any MMBasic code for accessing this module and retreiving data?
I am trying to un it with a raspberry Pi.
Many thanks
Roy
Posted: 11:52am 23 Feb 2025
The module appears to be based on the VL53L1X chip. Gave the data sheet a quick glance and it appears similar to the VL53L0X that I have, so if you compare the data sheets of both you may be able to adapt this MMBasic program for a PicoMite to your unit.
At a minimum you will need to change the address to &H52
'VL53L0X laser distance using System I2C on I2C channel 1
 'change all I2C to I2C2 if System I2C is on channel 2
Dim Integer dist
Const VLaddr=&H29 'VL53L0X I2C address
  VL53L0X
  Print dist
  Pause 2000
Sub VL53L0X
  Local Integer dst(1)
  I2C write VLaddr,0,2,0,1   'trigger VL53L0X measurement
  Pause 75  'allow time to perform measurement
  I2C write VLaddr,1,1,30    'prepare to read
  I2C read VLaddr,0,2,dst()  'get the data
  dist = (dst(0)<<8) + dst(1) - 20  'assemble the bytes and subtract the offset.
End Sub
Edit.
You might need to increase the size of array dst(1), but I am not certain.
Eg if there are 3 bytes of data use dst(2) and
  dist = (dst(0)<<16) + (dst(1)<<8) + dst(2) '+ offset if needed
Edited 2025-02-23 22:12 by phil99
foxleyboy
Posted: 01:53pm 23 Feb 2025
Many thanks Phil99. Will try this out.
stanleyella
Posted: 03:16pm 23 Feb 2025
I found this that worked.
OPTION DEFAULT NONE
'VL53LOX laser distance measurement.
Const I2Caddr=&H29   'VL53LOX device address
Dim d$
Dim integer dst(1)
'I2C open 100,1000   'Comment out for System I2C
I2C write I2Caddr,0,2,&H89,&H1
Font 2
Pause 200
CLS
text 0,0, "Integer"+ "String"
get.dist.str
Pause 200
get.dist.int
text 0,0, str$(dist.i%, dist.s%)
Pause 200
Sub get.dist.str                   'Get distance using a string
I2C write I2Caddr,0,2,0,1
I2C write I2Caddr,1,1,&H1E
I2C read I2Caddr,0,2,d$           'read 2 character string
dist.s% = Str2bin(uint16,d$,BIG)  'convert string to integer
Text MM.HRes/2,MM.VRes/3,"  "+Str$(dist.s%)+"mm  ",cm
End Sub
Sub get.dist.int                   'Get distance using integers
I2C read I2Caddr,0,2,dst()        'read 2 bytes
dist.i% = (dst(0)<<8) + dst(1)    'combine 2 bytes
Text MM.HRes/2,MM.VRes*2/3,"  "+Str$(dist.i%)+"mm  ",cm
End Sub
Posted: 08:07pm 24 Feb 2025
The address given in the datasheet is &H52 but it incorporates the R/W bit as the LSB.
MMBasic uses a 7 bit address and separate R/W bit so:-
hex$(&H52 >> 1) = &H29 - Same as VL53L0X.
If you are using a recent beta firmware you can use LIST SYSTEM I2C to show everything on the SYSTEM I2C bus.
eg
> LIST SYSTEM I2C
HEX  0  1  2  3  4  5  6  7  8  9  A  B  C  D  E  F
00: -- -- -- -- -- -- -- -- -- -- -- -- -- -- -- --
10: -- -- -- -- -- -- -- -- -- -- -- -- -- -- -- --
20: -- -- -- -- -- -- -- -- -- 29 -- -- -- -- -- --
30: -- -- -- -- -- -- -- -- 38 -- -- -- -- -- -- --
40: -- -- -- -- -- -- -- -- -- -- -- -- -- -- -- --
50: -- -- -- 53 -- -- -- -- -- -- -- -- -- -- -- --
60: -- -- -- -- -- -- -- -- 68 -- -- -- -- -- -- --
70: -- -- -- -- -- -- -- -- -- -- -- -- -- -- -- --
Edited 2025-02-25 08:56 by phil99
