Local Time 04:12 11 Sep 2026 Privacy Policy
Forum Index : Microcontroller and PC projects : Change GUI LED Colour
OA47
Posted: 09:47pm 25 Mar 2025
What is the easiest way to change the colour of a GUI LED given a flag before the CtrlVal is enabled? Do I have to remove the GUI LED reference of one colour then re-instate the definition of a new colour?
OA47
Posted: 01:10am 26 Mar 2025
The best I could come up with is overlapping 2 LEDs. Then using a variable for #number.
CLS 255
GUI led #1, "LED", MM.HRes/2, MM.VRes/2, 88, 255<<16
GUI led #2, "LED",  MM.HRes/2, MM.VRes/2, 88, 255<<8
  Col% = 1
  CtrlVal(#Col%) = 2500
  Pause 4000
  Col% = 2
  Pause 4000
End
OA47
Posted: 02:18am 26 Mar 2025
This is the code I am using at the moment but I was wondering if there was a more elegant way of achieving the result.
Sub BlinkLED
If RadMsg=1 Then
 GUI DELETE #37
 GUI LED 37, "",118, 38, 10 , RGB(White)  'Action Indicator LED White
Else
 GUI DELETE #37
 GUI LED 37, "",118, 38, 10 , RGB(Red)    'Action Indicator LED Red
End If
 CtrlVal(37)=1:Pause 100:CtrlVal(37)=0    'Pulse LED to indicate operation
End Sub
OA47
Posted: 03:00am 26 Mar 2025
This does the same thing.
CLS 255
GUI led #37, "", 118, 38, 10, RGB(WHITE)
GUI led #38, "", 118, 38, 10, RGB(RED)
  BlinkLED
  Pause 2000
  RadMsg = NOT RadMsg
End
Sub BlinkLED
  If RadMsg Then
    Col% = 37
   Else
    Col% = 38
  EndIf
  CtrlVal(Col%) = 100  'Pulse LED 100mS to indicate operation
End Sub
Edit.
Well it does when running the program above but at the command line it just stays on.
So at the prompt you do need the pause then switch off:-
CtrlVal(Col%) = 1 : Pause 100 : CtrlVal(Col%) = 0
Edit 2.
One less line.
CLS 255
  BlinkLED
  Pause 2000
  RadMsg = NOT RadMsg
End
Sub BlinkLED
  If RadMsg Then
    CtrlVal(37) = 100  'Pulse LED white for 100mS to indicate operation
   Else
    CtrlVal(38) = 100  'Pulse LED red for 100mS to indicate operation
  EndIf
End Sub
Edited 2025-03-27 09:20 by phil99
