Local Time 17:50 21 Sep 2026 Privacy Policy
Forum Index : Microcontroller and PC projects : PcoMite "Variable" question
stef123
Posted: 05:14am 27 Mar 2025
i have a few programs which should be called by a Main program, because they wont fit together into one.
I am in the need to swap between the main program and other Programs by Request, but the underlying programs shouldnt do certain intialisations again after being called the first time (since bootup of the Pico).
One method which came into my mind was fiddling around with an external, small Table per Program, stored in the File area, which contains the last (not the actual!) boot count, compare it to the actual bootcount and write the actual count back into the file. This would inhibit those programs to perform some actions again, after being called the first time since booting up, which i want.
But i wonder if there is a better method by using in SRAM a fixed, free available memory area of a certain size which can be used for that purpose by poking and peeking it. But since the variables of the programs are different in their amount and size, i cannot assure that a certain memory area is always kept free (i'm using GUI controls on an attached GLCD as well, btw).
I know about the "var"- Command, which stores variables in NVRAM, but if i understand the manual correctly, any time when a new program is loaded and being started, the 16K NVRAM area will be overwritten, because i assume that loading and running a program, other than the currently running program, is equal to performing a "NEW" or "autosave" command. Or am i wrong in my assumptions?
In case of poking and peeking into memory - are SRAM areas also being erased as soon as i start another program, or are they consistent unless i power off and back on?
Best regards!
Stef
Edited 2025-03-27 15:21 by stef123
Posted: 08:51am 27 Mar 2025
Would CHAIN be good enough?
PhenixRising
Posted: 11:13am 27 Mar 2025
I am a bit challenged when it comes to comprehending these types of questions but if I'm on the right track, would the memory in a RTC device be of any use?
Posted: 11:30am 27 Mar 2025
If you are having problems fitting all the programs into memory are you being efficient? Could you use the Library to hold several routines that all your programs need so that they then don't need to appear in any of them? The Library routines could use LOCAL and/or STATIC variables so that you need less globals.
You could also use the Library to automatically set up some globals every time you boot.
Then there's:
  Quote  CHAIN fname$ [,cmdline$] ' Allows the program to run another program with the variable space preserved - command is recommended to be used in top level program and not from within a subroutine (may work OK but not tested for side-effects)
SAVE CONTEXT [CLEAR]' saves the variable space and optionally clears it - command should be used in top level program and not from within a subroutine (may work OK but not tested for side-effects). If used in a subroutine a subsequent LOAD CONTEXT must DEFINITELY be in the same subroutine or a crash/corruption will DEFINITELY happen.
LOAD CONTEXT [KEEP]' restores the variable space to the previously saved state and optionally preserves the stored variables to allow a second LOAD if required.
Edited 2025-03-27 21:33 by Mixtel90
stef123
Posted: 12:11pm 27 Mar 2025
The thing is that i am using the Pico for controlling several external Synthesizers with different GUI apperances, Many different control structures, different memory mappings and so on.
Each program is fairly complex and has a lot of tables in it, especially for memory mapping (which CC/NPRN/Sysex is mapped to which internal memory address of the Pico and if, which bit pattern at a certain memory adress of the Synthesozer is assigned to which control etc) and vice versa, Tables for mapping values from 0 to 127 to certain control names (eg for an Oscillator "SAW", "TRIANGLE", "PULSE") and so on.
One Program alone eats 40 up to 50K of Memory - which i consider as rather small for that given purpose.
I wont crawl trough tables by Filesystem IO while modifying controls, this would add a lot of overhead and the Pico has to handle Midi I/O as well - for example buffering and merging modified control Data into the Midi Data Stream from the PC through the Pico and to the Synthesizers - as fast as he could. So everything should be kept in SRAM as much as possible.
Yes, there are some routines which are naturally used by all of these programs. but fitting everything into one single Program wouldnt do it anyway. Perhaps in Assembly, but i wont do that.
There is some potential for optimization, but not much. Recreating everything in order to keep the main program as small as possible and fit -every- need, from tables to different GUI appereances and memory assignments into one (or more) fairly large, external File and load it when its needed would be not impossible, but an quite complex task, which i want to avoid.
Writing the programs themself including implementing new GUI control methods, doing sometimes some faily complex Math and crawling through the Midi Implementation Charts of each Synthesizer was, to be honest, already complex enough.
Anyway, thanks for the hint to "chain" and the other commands. I will try what i can do with them.
