Forum Index : Microcontroller and PC projects : Drawing Robot
| PhenixRising Guru Joined: 07/11/2023 Location: United KingdomPosts: 2076 |
I like stuff that actually moves Would be cool to have a PicoMite version |
| DaveJacko Senior Member Joined: 25/07/2019 Location: United KingdomPosts: 105 |
sorry to bang on about me, but I was rather proud of my drawing machine.. made from a Micromite, cheap stepper module, 2 motors, RC servo and some string. a mercifully short video here.. https://www.youtube.com/watch?v=Buybf25-wbg I also like stuff that moves! Try swapping 2 and 3 over |
| Frank N. Furter Guru Joined: 28/05/2012 Location: GermanyPosts: 1153 |
That's cool! Would you post your code??? Thanks! Frank |
Love it...and the mouse trap |
| darthvader Senior Member Joined: 31/01/2020 Location: FrancePosts: 101 |
My own from 6 years ago Drawbot Plotter Theory is when we know everything but nothing work ... Practice is when everything work but no one know why ;) |
OK Frank, do you really want to see my code? This version just does up/down/left/right from the PC cursor keys so it is as simple as possible, I can explain more if needed.. ' gantry plotter demo DPJ 2020 username "DaveJacko" ' uses Pythag's theorem and Bresenham's line drawing algorithm init Pin(enabpin)=0 ls=9333 'steps=350mm = plot area size in steps xnow=ls/2 'start at centre of plot area ynow=ls/2 l1now=ls*0.707 '1/sqr(2) l2now=ls*0.707 '=250mm mainlp: ' --- the main loop t$=Inkey$ ' keypresses, u/d = pen raise/lower If t$="" Then GoTo mainlp If t$=" " Then Pin(enabpin)=1:PWM 2,stop: End If t$="u" Then penup If t$="d" Then pendn a$=a$+t$ If Len(a$)>3 Then a$=Right$(a$,3) If a$=lc$ Then moveby -1,0 'cursor keys move the pen around If a$=rc$ Then moveby 1,0 If a$=uc$ Then moveby 0,-1 If a$=dc$ Then moveby 0,1 GoTo mainlp Sub MoveBy(mbx,mby) ' moveby ie move pen relative to current posn. mbx=mbx*266 '=1 cm mby=mby*266 ' calc turns from mbx,y l1now=Sqr(xnow*xnow+ynow*ynow) 'maybe +residual l1now l2now=Sqr((ls-xnow)*(ls-xnow)+ynow*ynow) xtarg=xnow+mbx ytarg=ynow+mby l1targ=Sqr(xtarg*xtarg+ytarg*ytarg) l2targ=Sqr((ls-xtarg)*(ls-xtarg)+ytarg*ytarg) l1mov=l1targ-l1now l2mov=l2targ-l2now Print "mbx,mby",,mbx,mby Print "xnow,ynow",xnow,ynow Print "xtarg,ytarg",xtarg,ytarg Print "l1now,l2now",l1now,l2now Print "l1targ,l2targ",l1targ,l2targ Print "l1mov,l2mov",l1mov,l2mov xnow=xtarg ynow=ytarg ' now turn motors by l1mov,l2mov 'directions.. If l1mov>0 Then Pin(dirxpin)=0 Else Pin(dirxpin)=1 If l2mov>0 Then Pin(dirypin)=1 Else Pin(dirypin)=0 'major axis is.. If Abs(l1mov)>=Abs(l2mov) Then 'l1 is major l1i=Sgn(l1mov) l2i=l2mov/Abs(l1mov) ni=Abs(l1mov) 'num of incs Print "l1 major" Else 'l2 is major axis l2i=Sgn(l2mov) l1i=l1i/Abs(l2mov) ni=Abs(l2mov) Print "l2 major" EndIf l1acc=0:l2acc=0 For i=1 To ni ' do move l1acc=l1acc+l1i l2acc=l2acc+l2i If l1acc>=1 Then l1acc=l1acc-1:Pin(stpxpin)=1 If l1acc<=-1 Then l1acc=l1acc+1:Pin(stpxpin)=1 If l2acc>=1 Then l2acc=l2acc-1:Pin(stpypin)=1 If l2acc<=-1 Then l2acc=l2acc+1:Pin(stpypin)=1 wait1 Pin(stpxpin)=0 Pin(stpypin)=0 Next i End Sub Sub init '---- init stpxpin=2 ' define step pins stpypin=3 stpzpin=4 dirxpin=5 '..direction pins dirypin=6 dirzpin=7 enabpin=9 stoppin=15 'servopin=26 pwm SetPin 2,dout SetPin 3,dout SetPin 4,dout SetPin 5,dout SetPin 6,dout SetPin 7,dout Pin(9)=1 'enable off SetPin 9,dout SetPin 15,din,pullup 'int? e$=Chr$(27) 'define escape uc$=e$+"[A" 'cursor keys up/down/right/left dc$=e$+"[B" rc$=e$+"[C" lc$=e$+"[D" SetTick 1,int1ms 'timer Pause 100 End Sub Sub penup ' lift the pen PWM 2,50,7 End Sub Sub pendn ' drop the pen PWM 2,50,10 End Sub Sub int1ms ' --timer subs iflag=1 End Sub Sub wait1 w1lp: If Not iflag Then GoTo w1lp iflag=0 End Sub Try swapping 2 and 3 over |
@DaveJacko: Thank you very much! I think I need to pick out a few stepper motors from my stash and build something... @darthvader: Did you also realize this with MMBASIC? Frank |
A couple of DC motors + encoders and the PicoMite could make it superfast |
| Mixtel90 Guru Joined: 05/10/2019 Location: United KingdomPosts: 9128 |
There's a limit to how fast you can draw a line on paper. :) We used to have fun with one of the old A3 pen plotters. Expensive pens always worked fine, some of the cheaper ones were decidedly dodgy as they got older. The ink simply didn't have time to get out of the tip on fast lines. Mind you, we could get a lot of cheap pens for the cost of one expensive one. :) Mick Zilog Inside! nascom.info for Nascom & Gemini |
Oh sure but closed-loop servo blows steppers away |
No , it was like a 3D printer with Marlin. Theory is when we know everything but nothing work ... Practice is when everything work but no one know why ;) |
