Forum Index : Microcontroller and PC projects : Can MMbasic access larger system flash ?
| vincenthimpe Regular Member Joined: 14/10/2018 Location: United StatesPosts: 86 |
The default Pico module comes with a 2MB flash memory However, the rp2040 can use up to 16Mb using a W25Q128. Can the interpreter use this extra space as drive A ? Trying to avoid requiring an external SDcard. I'm rolling my own board using a bare rp2040 so i can stick any QSPI flash there i want. |
| PhenixRising Guru Joined: 07/11/2023 Location: United KingdomPosts: 2076 |
Already does this |
| Mixtel90 Guru Joined: 05/10/2019 Location: United KingdomPosts: 9114 |
AFAIK the flash is allocated for the firmware, then the flash slots 0-3 then any remaining up to the limit is allocated to A:. I have some YD-RP2040 16MB clones that use the remaining available space so I assume that's how MMBasic handles it. :) Mick Zilog Inside! nascom.info for Nascom & Gemini |
great ! |
