Local Time 20:22 10 Sep 2026 Privacy Policy
Forum Index : Microcontroller and PC projects : Webmite limit of 252Mhz ?
DigitalDreams
Posted: 07:37am 26 May 2025
Why is Webmite limited to 252Mhz ?. Ran a Pico 2 successfully at 360Mhz using Picomite. Issues with flash, Pimoroni psram and WiFi modules on all can surely be dealt with by correct timing/divider settings....
Posted: 08:07am 26 May 2025
I think it was found the Wi-Fi chip can't handle higher speeds.
If it could have been solved by tweaking settings Peter would have done that.
Edited 2025-05-26 18:09 by phil99
Posted: 08:21am 26 May 2025
I think a cheap UART-WiFi bridge module is probably better than the Pico W. There are less limitations!
DigitalDreams
Posted: 08:29am 26 May 2025
  phil99 said  I think it was found the Wi-Fi chip can't handle higher speeds.
Yes yet my Pimironi Pico Plus 2W won't even boot at 252Mhz, reached 242Mhz, guessing the psram timings/divider are unsuitable. Needs a specific build.
Footnote added 2025-05-27 03:43 by DigitalDreams
Reached 238Mhz, failed at 240Mhz.
DigitalDreams
Posted: 08:37am 26 May 2025
  Mixtel90 said  I think a cheap UART-WiFi bridge module is probably better than the Pico W. There are less limitations!
Yes it seems that way and considering a BL-M8731BU3 RTL8731BU Dual Band 2.4G/5G external module for the Luckfox Lyra 256Mb when I get round to figuring out the builds for it (no Linux experience). If that would work on a standard Pico2 at 360Mhz and be picked up by Webmite with no modification I'd be happy.
PhenixRising
Posted: 10:44am 26 May 2025
I recommend the ESP32. Not a fan of the Arduino IDE but pretty much whatever you can dream of is already written. Just hook-up to the PicoMite Rx/Tx.
This was all I used
Posted: 10:56am 26 May 2025
The  Pimironi Pico Plus 2W isn't supported by MMbasic and won't be supported. The Pico2-W is fully supported at up to 252MHz. Above this even with the PIO divide ratio changed the Webmite firmware isn't stable enough for reliable use. PIO is used to talk to the wifi module
Edited 2025-05-26 20:59 by matherp
DigitalDreams
Posted: 05:44pm 26 May 2025
  matherp said  The  Pimironi Pico Plus 2W isn't supported by MMbasic and won't be supported. The Pico2-W is fully supported at up to 252MHz. Above this even with the PIO divide ratio changed the Webmite firmware isn't stable enough for reliable use. PIO is used to talk to the wifi module
We need a Pico 3W !
PhenixRising
Posted: 06:22pm 26 May 2025
Nah. We need support circuitry anyway for most designs. Why burden the limited resources of the Pico.
This is why I use a low cost Android device as the front end....everything is there; WiFi, Bluetooth, memory, GPU, screen, capacitive touch, instant availability if the much abused user-interface dies.
Save the Pico resources for lesser mundane tasks.
