Forum Index : Microcontroller and PC projects : need for kicad a working pcb picomite vga
| tenij000 Senior Member Joined: 30/05/2025 Location: NetherlandsPosts: 107 |
i try the version 1 then some files are missing if load it in kicad the gerbers end up whit a tiny mini pcb cant transfer it to the pcb editor place wondering is there a version that is kicad compatibole youst can load |
| Geoffg Guru Joined: 06/06/2011 Location: AustraliaPosts: 3367 |
The original design was done in Eagle but I do not have a licence anymore, and I did not export a kicad version. So, sorry, I cannot help. Geoff Geoff Graham - http://geoffg.net |
ok then i give this a go 2.8 inch TFT Display 240*320 pixels with Touchscreen - SPI - ILI9341 - 3.3V |
| Andy-g0poy Regular Member Joined: 07/03/2023 Location: United KingdomPosts: 85 |
Have you tried the import eagle project from the kicad file menu? Andy |
