Local Time 22:27 25 Oct 2026 Privacy Policy
Forum Index : Microcontroller and PC projects : Saving the entire pico "image" - .uf2 ??
Nimue
Posted: 07:54pm 16 Jun 2025
Sorry all for the seemingly random questions - working on two projects at the same time that are now coming together.
Both lead to the the following question.
Say I have a functioning 'picomite project (Single BAS file, or a couple of smaller ones.).
Is there a way to save the entire 'mite state into something like a .uf2 file so that a user just needs to "flash and go"?
Trying to avoid sending the code and a user needing to upload a BAS file using TeraTerm or MMC.
This is not about copy protection - happy that they can see / edit the BAS - literally looking for a method similar to the flashing approach.
I know this is not part of MMBASIC - but buried in the PICO SDK or whatever, is it possible to take what's currently on a PICO and sort of clone it back to a UF2 -- to literally clone what's on it?
N
stanleyella
Posted: 08:23pm 16 Jun 2025
try save option list and reflash new and redo options
Amnesie
Posted: 08:37pm 16 Jun 2025
Hello,
if I understand you correct, this is not a problem at all! I tried this many times.
It does a 100% clone of your pico including all of the options and the program in flash. This works with the pico1 and pico2!
Just google for: "picotool-2.1.1-x64-win" there is a github with binaries, so you do not have to compile it yourself! Or use this link:
https://github.com/raspberrypi/pico-sdk-tools/releases
Then:
1. Plug the Pico in while holding down BOOTSEL switch
2. run a terminal window in the folder, in which picotool.exe is located and:
3. Run this command: picotool save -a filename.uf2
there you go... I really love that this is possible!
Greetings
Daniel
Edited 2025-06-17 06:42 by Amnesie
Nimue
Posted: 09:44pm 16 Jun 2025
  Amnesie said  Hello,
Then:
Greetings
Daniel
Perfect - exactly what I was looking for.  I'll grab those files.
Diolch
N
PhenixRising
Posted: 08:06am 17 Jun 2025
  stanleyella said  try save option list and reflash new and redo options
Hi Stan,
The cool thing about saving with Picotool is that the entire image is saved, including MMBasic.
If you have extended MMBasic with library routines, for example, you now have a single uf2 to program other devices with.
stanleyella
Posted: 09:10pm 17 Jun 2025
Hi Stan,
I'll check it. thanks
twofingers
Posted: 09:50pm 17 Jun 2025
deleted, wrong thread.
Edited 2025-06-18 07:51 by twofingers
