Local Time 22:28 25 Oct 2026 Privacy Policy
Forum Index : Microcontroller and PC projects : Saving 'list' output ?
DigitalDreams
Posted: 09:39pm 17 Jun 2025
'list pins' outputs to the screen too quickly and the first 7 lines or so scroll off the top of my screen. Slowing the processor doesn't help.... Is there any way to pause this output or even better save to text file or string ?
twofingers
Posted: 09:51pm 17 Jun 2025
Maybe this helps?
' FREEPINS() 2024 by Volhout
Sub FREEPINS()
Local integer n,p
Local string gp$,pu$
For n=0 To 29
 gp$ = "GP"+Str$(n)
 On error skip
 p = MM.Info(pinno gp$)
 If Not MM.Errno Then
   pu$ = MM.Info(pin p)
 Else
   p=-1
   pu$=MM.ErrMsg$
 EndIf
 Print gp$;@(50,MM.Info(vPOS)) p, pu$
Next
End Sub
Michael
DigitalDreams
Posted: 10:05pm 17 Jun 2025
  twofingers said  Maybe this helps?
Michael
Sure does thanks !
