Local Time 21:37 25 Oct 2026 Privacy Policy
Forum Index : Microcontroller and PC projects : do think this good screen that the touch works
tenij000
Posted: 02:44am 25 Jun 2025
https://www.otronic.nl/nl/28inch-tft-touch-screen-320x240-ili9341-spi.html?source=googlebase&gad_source=1&gad_campaignid=19639985996&gbraid=0AAAAACZK5qu7s0geR-8fgyUtjw3fcqD7t&gclid=CjwKCAjwmenCBhA4EiwAtVjzmqBWbdttJMeD01RmEdNu2uWq6Z_FDnFLhO5wXpABgZ796eB9gwnLKBoCr_IQAvD_BwE
PhenixRising
Posted: 07:08am 25 Jun 2025
Tip: This is the only portion of the link that's required (everything up to the "?")
  Quote  https://www.otronic.nl/nl/28inch-tft-touch-screen-320x240-ili9341-spi.html
But even better as a direct link
Use this button to create the direct link:
PhenixRising
Posted: 07:13am 25 Jun 2025
A quick search suggests that the OT3239 is the same as:
  Quote  OPTION LCDPANEL ILI9341
But that was Google. I know very little about these interfaces.
Posted: 07:15am 25 Jun 2025
I9341 is one of the main "bread and butter" displays for the Pico. That's the "reference" display if you like. It has some disadvantages over some of the newer displays, but it does most things ok. I prefer the 3.2 inch version personally.
Incidentally, when you post a link you only need the part before the ? character. The rest is tracking information and stuff.
You can put a link into a post using the Link button (the one with a chain link over a globe). You are prompted for the text that you want others to see then for the actual HTML link itself. All you see in your post when it's uploaded is the text.
Posted: 08:27am 25 Jun 2025
The OPs original question is about touch compatibility. In that link it doesn't say which touch chip is used but in the photo it looks like the standard resistive foil and chip.
The PicoMite supports XPT2046 resistive and FT6336 capacitive touch chips.
Resistive is the default and OPTION TOUCH FT6336 for capacitive.
Edited 2025-06-25 18:29 by phil99
Marcel27
Posted: 05:25am 26 Jun 2025
What about this  one?
A little more expensive.
EDIT: WIKI See mmbasic manual: The Waveshare should not MISO have issues.
OPTION LCDPANEL ILI9488, OR, DC, RESET, CS [,BL] [,INVERT]
Initialises a TFT display using the ILI9488 controller. This supports 480 * 320 resolution. Note that this
controller has an issue with the MISO pin which interferes with the touch controller. For this display to work the
MISO pin must not be connected.
OPTION LCDPANEL ILI9488W, OR, DC, RESET, CS [,BL] [,INVERT]
Initialises a TFT display using the ILI9488 controller. This supports the Waveshare 3.5" display as used on their
Pico Eval board and the normal 3.5" display adapter.
Edited 2025-06-26 15:40 by Marcel27
