Grogster Admin Group Joined: 31/12/2012 Location: New ZealandPosts: 10074
Posted: 10:11am 31 Jul 2025
This is interesting. MMBASIC 5.0706, VGA version.
To be sure everything was wiped, first I issued the command: DRIVE "A:/FORMAT" That worked.
Next, I tried to copy a small 47k BMP file to the A: drive, and the PM moans there is not enough space.
MM.INFO(DISK SIZE) says 786k free.
WTF?
EDIT: Might be a bug from an earlier version. I will update the FW. Edited 2025-07-31 20:23 by GrogsterSmoke makes things work. When the smoke gets out, it stops!
matherp Guru Joined: 11/12/2012 Location: United KingdomPosts: 12059
Posted: 10:23am 31 Jul 2025
Try copy "rictech2.bmp" to "A:/rictech.bmp" Your current statement isn't valid syntax You can only use "a"/" when copying from a directory. Of course the version you are using is so old who knows what else may be the issue
Posted: 10:39am 31 Jul 2025
Great, that did fix the copy, but as you say..... I will update the FW before I do anything else. Been a long day and I also have the flu, so my brain is not firing on all six cylinders as it should, I guess. Smoke makes things work. When the smoke gets out, it stops!
