Local Time 18:25 25 Oct 2026 Privacy Policy
Forum Index : Microcontroller and PC projects : Meta AI
Bryan1
Posted: 07:22am 10 Aug 2025
So I just asked Meta AI a question
Posted: 07:36am 10 Aug 2025
Perhaps rephrase the question with a bit more detail.
"On a Grain Oriented Silicon Steel transformer core with a cross-section of X square millimeters and magnetic circuit length of Y millimeters, how many turns of wire will be needed for 1 Tesla at 240 volts and 50Hz?"
Replace X and Y with your measurements.
Edited 2025-08-10 17:38 by phil99
Bryan1
Posted: 07:45am 10 Aug 2025
phil I asked the same question in co pilot and got a valid answer I will go more into it in my toroid thread
Posted: 07:57am 10 Aug 2025
TBH it's not a well phrased question. If you'd asked how many turns were needed for a specific core to develop a flux density of 1 Tesla then you might have stood more chance. The key words are "flux density". You didn't specify what you were looking for.  :)
You will also need to specify any data that it will need to work with. If you are lucky and omit something it might prompt you for it.
AI is intelligence-free.
